Question about Kodak Zx1 Digital Camera
Can I use my Kodak ZX1 as a webcam for Skype?
Need instuctions
Click here for the user guide.
Click here for the extended user guide.
Nov 13, 2012 | Kodak Zx1 High Definition Flash Media...
Control Center for KODAK Webcams. I have installed the software that came with my NEW KODAK S101 Webcam but when I open Control Center for KODAK Webcams all I get is a black screen.
I had the same problem today. I did some research and found that the software is trying to go to a website that no longer exists, or at least is not functioning right now.
I found out that the Kodak webcam which is the D101 is plug and play. I just plugged it in and I have already used Skype.
Sep 04, 2011 | Computers & Internet
Does the kodak webcam s101 work with skype ??
Yes it does, just make sure you have all the latest drivers to avoid any performance issues.
Aug 20, 2011 | Kodak S100 Webcam
Webcam doesn't work with skype
reinstall webcam driver for your operating system, then from skype configur it,
Jun 03, 2011 | Kodak S100 Webcam
I am attempting to upgrade the firmware on my Zx1 camcorder from version 1.02 to 1.06. I used the the SD/SDHC previously used to extend the camera memory, (with content deleted), to load from my computer...
Did you make a directory on the card called System? It needs the capital S. Put both the files from the unzipped directory (C:/kodak probably) into the System directory on the card and boot the camcorder ensuring there's lots of life in the batteries. I just did it, from 1.02 to 1,06 too, and it worked a treat. The differences aren't huge but the audio is clearer now. Hope that helps.
Jan 24, 2011 | Kodak Zx1 Digital Camera
Kodak ZX1 shuts off randomly every time while in use. Won't stay on for then a few min.
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be due for replacement, or the camera may have a problem that requires professional repair.
Dec 05, 2009 | Kodak Zx1 Digital Camera
Kodak Zx1 Digital Camera Logo
691 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
