Question about Oregon Scientific WW338 Cordless Phone
Hello. We have a three-year-old Oregon Scientific phone, model # OS1820L-HK. We are unable to press any button any longer in order to make phone calls. However the phone still works for incoming calls. Looking forward to your expert help. Thank you.
  • Oregon Scien... Master
  • 19,396 Answers
Hi.
In case you have not fixed the problem yet, try doing a full system power reset. This is done performing the following, simply disconnecting the power adapter won't be enough:
  • Disconnect all power adapter cables from wallsockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handsets to cradles. If that does not work, then some of the units comprised in the system is defective.
US ' Customer Service
UK contact page.
Global website.
Regards.
Ginko.
Posted on Jan 13, 2011
Unable to cancel min. wind chill reading wnen current display reads NA; thus 5C still shows from a day in April!
There is a reset button on each sensor unit and there is a reset on the base display. The NA means that the signal is not being sensed from the remote. If you use the reset button on the base you will lose all the historical data. The problem may be related to strong interference from something else nearby, You can bring the sensor inside to see if the base picks it up. IF it does not it may need to be replaced. I have dealt with Oregon Scientific before and they are very good with their support. http://www.oregonscientificstore.com/WMR86A-Oregon-Scientific-Backyard-Pro-Wireless-Weather-Station.product
Jun 27, 2014 | Oregon Scientific WMR86A Backyard Pro...
Oregon scientific instructions
Which model Oregon Scientific do you have? There are a couple that you need to set the time zone with a switch on the back of the unit. For the BAR388HGA-BK, you press and hold Mode for 2 seconds until it goes into the setting mode. Then you can use the up/down arrows to cycle through the Time Zone options. (1 is Pacific, 4 is Mountain). Press Mode again to confirm the setting and advance to the next item to change. You will leave the Set mode if you do not press a button for several seconds. If you just press and release the Mode button, then you can set the time display option.
A number of Oregon Scientific product manuals are available here:
Technical Support , http://www.oregonscientific.com/us/en/service/support . Scroll down and see the drop-down menu on the right.
I hope this helps.
Jan 25, 2014 | Garden
Oregon wmh90 error eep
The message "error eep" is display on the main unit. I checked and changed the all the batteries, I pressed the reset button both on the main unit and on the outdoor unit and this message is still displayed.
Can someone help me
Thanks
Jan 25, 2013 | Oregon Scientific Measuring Tools &...
I have found my old oregon scientific camera DS6618. I finally found drivers for it at driversguide.com, downloaded and ran the program and each time it says it can not open the setup.exe file, so...
If the camera is so old that it's no longer listed on the manufacturer's website, then you will not be able to find current drivers for it regardless of what driversguide.com said. If the camera uses a memory card, you could always use a card reader to download the pics. typrice_133.jpg
Feb 16, 2011 | Oregon Scientific DS6618 Digital Camera
Oregon Scientific RRM326P Snooze button won't work with radio
this is internal speaker control volume defect, please send to repair shop for repair.
Nov 29, 2009 | Audio Players & Recorders
I have two Oregon Scientific systems. they are interfering.
Two things...
1) press reset on the base unit
2) press and hold for 2-3 seconds the channel button
You should be in business
Apr 11, 2009 | Oregon Scientific Lwb0997110113004...
Operating Instructions Model No BA218
Setting the time and calendar
1. Press the [TIME] button once to enter Time Mode. The display shows the current time with hour, minutes, and seconds digits.
2. Press and hold the [SET] button for more than one second. The "Hour" digits of the time will begin flashing.
3. While the "Hour" digits are flashing, press the [^] or [down] button to set the desired hour time. Note: Press the [^] or [down] button once to advance the setting forward or backward by one digit. Pressing the [^] or [down] for more than one second will accelerate the forward or backward setting at a higher rate.
4. When the desired hour time is reached, press the [SET] button again. The "Hour" setting will be confirmed and the "Minute" digits will begin flashing.
5. While the "Minute" digits are flashing, press the [^] or [down] button to set the desired minute time.
6. When the desired minute time is reached, press the [SET] button again. The "Minute" setting will be confirmed and the "Year" digits will begin flashing.
7. While the "Year" digits are flashing, press the [^] or [down] button to set the desired year.
8. When the desired year is reached, press the [SET] button again. The "Year" setting will be confirmed and the "Month" digits will begin flashing.
9. While the "Month" digits are flashing, press the [^] or [down] button to set the desired Month.
10. When the desired month is reached, press the [SET] button again. The "Month" setting will be confirmed and the "Date" digits will begin flashing.
11. While the "Date" digits are flashing, press the [^] or [down] button to set the desired Date.
12. When the desired date is reached, press the [SET] button again. The "Date" setting will be confirmed and the calendar setting is complete.
Feb 21, 2009 | Oregon Scientific WW338H Weather Station...
Setting the alarm
Hold down the button labelled 24hOFF for several seconds, the alarm hour digits will flash, adjust using up down arrow buttons and change to minutes by pressing 24h button again.
Aug 18, 2008 | Oregon Scientific OR-RM313PA ExactSet...
Oregon Scientific WW338 Cordless Phone Logo
154 people viewed this question
Top Oregon Scientific Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an Oregon Scientific Lands Phone Expert? Answer questions, earn points and help others
