Acson G12 remote programing button - Televison & Video
UNABLE TO START THE Acson AIRCOND 2.5 WITH BOTH THE REMOTE CONTROLLER AS WELL AS THE ON OFF SWITCH
Make sure there is power going to A/C. If there is, unplug A/C from wall or shut power off at fuse box for 20 minutes. Make sure the batteries are new.
May 16, 2016 | Heating & Cooling
Why won't the screen on my Canon G12 display an image so I can take a photo??
The Display button toggles the information shown on the LCD (or turns it off entirely). Make sure you haven't inadvertently pressed it and turned off the display. It works as follows:
  • Press once for Normal view in LCD viewfinder
  • Press twice to turn on Rule of Thirds grid lines
  • Press three times to turn off LCD display
  • Press and hold 1 sec. to decrease/increase LCD brightness
Aug 02, 2014 | Canon Powershot G12 10 Megapixel Digital...
Display not working on g12
Jan 05, 2014 | Canon G12 Digital Camera
Acson remote code
To which device do you want setup codes. Provide more details please. If you wish to get more details, check this site. http://electronicshelponline.blogspot.com/ Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Check this site too. http://electrohelponline.blogspot.com/
Apr 28, 2013 | Televison & Video
How do i delete all the pictures at once of my G12 camera
Press the arrow button to se the last picture taken, then "Menu" and select "Erase" with the "Set Func" and follow instructions.
Good luck
Oct 08, 2011 | Canon G12 Digital Camera
Canon G12 Digital Camera canon g12 screen problem it show black screen
CCD Problem. Go to this site: www.CamerasAndParts.com They have a fix for this problem on the G12. They are super for help with the Canons.
May 30, 2011 | Canon G12 Digital Camera
I have a 2000 reg polo i want to put water in for the enginge and it says G12 with a picture of a book and a ! inside the pick what is this? please
A new "G12" coolant additive, recognized by its red color, has been introduced during m.y. 1997, replacing the "G11" used previously.
The "G11" and "G12" coolant additives are NOT interchangeable, and must NEVER be mixed. Use only water or "G12" coolant additive G 012 A8D A1 to top up cooling systems filled with "G12" = GLYSANTIN Alu Protect/G30 silikatfrei
Once coolants stabilize and provided the system remains sealed and airtight (has not overheated where it vented) then the system should not require any flushing or changing of the coolant (specific to HOAT/G12 type coolants).
G12 after about 5,000-10,000 miles reaches that point of stability where the coolant has neutralized any reactions that may occur. As long as that stability is not thrown off, leave it alone.
In the case of the TDI the water pump requires replacement, this should be the only time that the cooling system is drained and flushed and the system refilled. sticking with G12 insures that the original balance of chemicals are maintained as close as possible to the stabilization point to eliminate any risk of system contamination or corrosion.
It's really simple, G12 out, G12 in, to insure system protection and integrity.
May 21, 2011 | Volkswagen Polo Cars & Trucks
I am unable to set the Digital Zoom to On, in my Canon G12. The Digital Zoom Option in the Camera Menu always seems to stay blanked out no matter what I do. Discussions with fellow G12 owners did not...
The digital zoom setting is only available when the aspect ratio is set to 4:3. The setting is accessible by pressing the 'func.set' button in shooting mode.
Mar 17, 2011 | Canon G12 Digital Camera
Televison & Video Logo
166 people viewed this question
Top Televison & Video Experts
Electro Med Services...
