I get this black screen message: Widows could not start because of a computer disk hardware configuration problem. Could not read from the selected boot disk. Check boot path and disk hardware. Please check the windows documentation about hardware disk configuration and your hardware reference manuals for additional information.
    Brigadier General:
  • 8,909 Answers
Try starting your laptop in safe mode. If it does then run CHKDSK/F to find and attempt to repair the errors on the drive.
Hope that helps
Posted on Jan 04, 2011
Audio windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope it helps
Jul 20, 2012 | ASUS P5PE-VM Motherboard
Asus eee 900 disk hardware configuration
Have you checked BIOS settings to make sure the right harddisk is selected as Boot Drive ?
You could try installing it on another machine to make sure it's still readable.
Did you change any settings or get any error messages the last time you used it ?
Jun 18, 2012 | ASUS Eee PC 900 Notebook
Black screen white flashing cursor
When this happens, you either have a hardware or bios problem. First thing to try is to re-start your comptuer and hit the F8 key this time. This should give you a menu including start in safe mode, start in Last known good configuration. Try selecting last known good configuration and see if this works. If not, try starting in Safe mode.
If this does not have work, re-start your computer and hit the F2 key to go into setup. This will be your BIOS, or Basic Input and Output Settings. You can go thru the tabs and see if you hard drive is recognized. Look under IDE configuration. If your hard drive is listed properly, then you motherboard is seeing your hard drive.
Then, go to the tab on the far right and look for reset bios or load system defaults. Sometimes, this will help you get by this problem.
IF none of this will work, then you ma have a hardware problem. If you have a operating system disk, you can put it in the disk drive and restart your computer. Look for a message to press any key to start with CD drive. Follow the prompts and reinstall windows. DO NOT format the drive unless you want to erase everything on your hard drive.
If this information helps you with your issue, please remember to leave positive feedback.
Thank You,
Brian
Feb 25, 2011 | Computers & Internet
I haven't had a recent hardware or software change but when I turn on my Dell Inspiron 1521 laptop I get a black screen with the following message: Windows Boot Manager Windows failed to start. A...
boot from an applicable boot disk & use fixmbr to repair the boot sector,
OR have you tried safe mode or last good....( you need to press F8 seconds after the PC is turned on)
Dec 31, 2010 | Dell Inspiron 1521 Notebook
Windows could not start because of a computer disk hardware configuration problem. Could not read from selected boot disk. Check boot path and disk hardware.
It appears that your system can't find any bootable device such as the hard drive. Go to system BIOS and check if the hard drive is detected. By pressing F2/Delete key while starting up it will boot up to your BIOS screen. You could also try to load the system BIOS default.
Dec 30, 2010 | ASUS Computers & Internet
Could be a serious problem.
next time you get it running, right click on my computer>explore, click on 'C' drive, right click>properties>tools tab, then click error checking, if the option to choose repair found faults, choose it, then the system will run a drive check.
It may take a few hours as it sounds as though you have a bad sector on your drive, back up all docs immediately after the system as run a check and hopefully is up and running again
Aug 16, 2008 | Dell Inspiron 6000 Notebook
Starts with a windows error message. press start normally then i get a black screen
Usually if that is the case the hard disk is corrupted that which means that some of the files in the booting system cannot be read properly. You can replace your hard disk or if there is a computer repair shop or technician near you, you can make it reformatted-that is to reset the the configuration of your computer- but the risk is the your files that you saved in the drive C will be lost and You can still recover it using the recovery software.
Aug 14, 2008 | Acer Computers & Internet
DESK TOP
recent u changed any hardware and software configuration
other wise u will change memory
Jul 17, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
