Question about Microsoft Xbox 360 Console
On off button keeps going red unit only 2 weeks old
  • 839 Answers
Firstly if you get the 3 red lights then Microsoft repair your console for free so long as you purchased it no more than 3 years before you send it back for repair. The 3 red lights are a sign of overheating, and to go into more detail this is what happens:
The 360 had a manufacturing fault or air vents were covered and so the 360 overheated, and got so hot that the solder balls on the cpu or gpu chip melted, and due to the fact the the 360 motherboard is able to flex a little, when the 360 was turned off and cooled down these solder balls solidified again, however they solidified in the wrong place or in two half's etc. and so the 360 shows the 3 red lights to indicate this fault.
Click here to download Microsoft xbox360 repair guide
Posted on Jan 04, 2011
Why does it keep turning off and on?
If only 2 weeks old I would return it. Definitely faulty.
Aug 26, 2015 | Samsung Galaxy S3 Neo DUOS I9300i 16GB...
Rheem heat pump,have to keep pushing red reset button for fan
Either the fan motor is going out OR the compressor may need a boost of power from a quick start.
When the compressor gets old, sometimes it requires a little extra power to get it going.
Your unit should be under work warranty if they installed it.
Jan 06, 2010 | Heating & Cooling
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Water not heating in Rilvia espresso machine
Hi
There is a reset button on the side of the boiler. Make sure that the machine is unplugged. Remove the water tank. Take out the 4 screws on the top. There are 2 black wires go to the high limit thermostat that has a red button in the middle. Push the red button.
Nov 07, 2009 | Rancilio Silvia Espresso Machine
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
My 18.2 cuft hotpoint refrigerator 2 years coils overheat
the drain on the unit is probebly clogged up or frozen . take and manually defrost the unit and check the drain line to see if i0ts clogged up.
Feb 01, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
My Drayton Digistat RF3 boiler control is not working. The thermostat module indicates it is sending a signal, but the unit beside the boiler has a red alarm LED lit. I've removed the batteries and turned...
I found that this solved the problem hope it helps you too.
come back on}
seconds.
received.
Nov 04, 2008 | Heating & Cooling
Hotpoint refrigerator not cold
There is a defrost timer that initates defrost for 30mins every 8hours of compressor run time. Take off the thermostat knob and the freezer damper knob, remove light guard. To the right of the thermostat, is the timer advancement screw it is small,and it looks like a plastic cam not a screw. you put the flat blade of a screwdriver and rotate click by click till unit shuts off (you will hear louder click and fans and comp will shut off. Now its in defrost. Wait 5mins open freezer remove lower bin look at drain hole where frost buils you shoud see the heater glowing red melting the frost. If no red glow and no heat from panel. You must go further with the diagnosis.. A solved rating will keep this expert advice coming...........
Oct 03, 2007 | EuroCave Performance 283 Wine Cellar
LD 37LC7D
This set has a modification that needs to be done. It will also start turning on by itself and changing channels rapidly. It's two weeks old. Take it back to the Retailer or if that is not an option contact LG at 1-800-243-0000 to get a local servicer in your area.
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
Microsoft Xbox 360 Console Logo
82 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
