When my KEF home theatre subwoofer is maxing out on bass, it often makes a loud popping noise. Should I be making some adjustments to reverb, volume, or something else?
  • 312 Answers
Yes you should make adjustments.KEF makes very good products, however if you don't handle this you will have to replace or service it.
1 If the woofer is very close to you, relocate it further away. The reason being is that the lower the frequency the larger the wave form. The lowest waveforms will become louder.
2 Adjust the high frequency cut off to be at 80Hz. This should eliminate boom. Higher Sub frequency tend to muddy the sound.
3 The sub should have a subtle effect in music. So the relationship between it and the speakers it augments the sound of should be seamless.
4 If you are playing Rap or Reggie music and you like to play it loud. Add another sub into the system and locate it NEXT TO the KEF Sub. In this fashion the two subs will reinforce each other's energy. They will "couple" thus multiplying their energy considerably.
Hope this helps,
Best Regards,
Mark
Posted on Jan 04, 2011
My kef subwoofer keeps making loud buzzing noise
Either you need new high quality cables,or your amp has output filter capacitor problems.
Aug 25, 2014 | KEF Audio Audio Players & Recorders
Tip
Noise Control and Being a Good Neighbour
Whether you live in a private dwelling, or in a multiple home dwelling, such as a condo or apartment building, one should pay attention to controlling the sound from home theatre and stereo systems. In this case, we are generally talking about managing the bass frequencies of the sound system. High frequencies tend to be absorbed by common building materials. The physical/mechanical aspects of sound transmission are complex, but the average person can apply some simple and inexpensive methods to minimize the unwanted transmission of bass frequencies beyond the listening space. <br /> Transmission of bass frequencies can often be controlled by placing bass-producing speakers on pieces of rubber material. These can be as simple as scrap pieces of rubber mat, salvaged rubber feet from other equipment, etc. The physical placement of speakers can determine the amount of bass frequencies that the sound system produces in the listening space. Generally, more bass is generated by placing speakers in corners, and along the shortest wall of a room. <br /> Of course, adjusting the bass and volume controls is a method that can be used to satisfy personal tastes or to control the sound in any situation. Many home sound systems now employ a subwoofer to provide enhanced bass response. This can add lifelike sound quality to the home listening experience, but it is probably the source of most noise complaints. The subwoofer channel of most video program sound tracks has more bass intensity than one generally finds in television, radio or music sound sources. To prevent disturbing the neighbours, one should employ all of the methods detailed above, to reach a happy medium of being able to enjoy full spectrum audio within reason. Personally, I ask my neighbours listen in their homes, while I adjust my maximum sound system volume to a level that they would not complain about. <br /> <br /> <br /> <br /> <br /> <br /> <br /> <br />
on Oct 28, 2010 | Audio Players & Recorders
Tip
Home theatre speakers
if you are using home theatre in a high sound,keep the BASS medium...if u r using a low sound,then keep ur BASS max...so that u can experience good quality sound. n also u can hav long life to ur speakers.............................................................................................
njoy
on Mar 02, 2010 | Audio Players & Recorders
I have a kef Kit100. My subwoofer is making a loud buzzing noise, what do I do?
You might have a bunch of bees living inside the sub?
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25.
Jan 18, 2009 | KEF Audio KIT100 System
Popping noise while computer is powering down. Any suggestions?
Lower your main sound volume. Double click the speaker icon in the bottom right hand corner of your windows.(was it maxed out?)
go into control panel /sounds and select a lower bass setting in your sound settings. You usually have a choice of rock & roll ( lots of bass) opera setting, classical etc.. choose one with less bass.
Make sure your LINE IN is DISABLED. It may be causing this static feedback.
You may have blown your speakers by playing sound way too loud. You may need to buy new speakers.
Thank you and Good luck. *s*
Oct 24, 2008 | EliteGroup P4M800PRO-M478 Motherboard
5.1 surround sound
Here is how you fix it. Its really easy actually take a look at your Subwoofer 99% of the time you can control two controls for your bass somewhere around the Subwoofer. If you raise the volume of your Subwoofer you'll get more bass. Try it and let me know how this works out for you alright.
Oct 03, 2008 | Audio Players & Recorders
Subwoofer clicking noise
Hi I am afraid it sounds like exactly the same problem I had, Namely the PSU(power suplly unit) is failing, This is a common fault (by reading loads of forums) I contacted KEF today about mine and they say the probably wont be able to source any more spares(due to so many having thuis problem no doubt) So I would suggest contacting the people you bought it from,Under the consumer protection act you should expect an electrical item to "Last a reasonable amount of time" .Mine is 3 years old and I do not consider this to be a long period so kick up and you should be entitled to a repair or at worst a partial refund.Look here basically the same Sub.
http://www.avforums.com/forums/showthread.php?t=436234&highlight=kef
Mar 04, 2008 | KEF Audio PSW 3000 Subwoofer
Subwoofer Bass Level Problems
What is your sub stood on? If it is on a piece of furniture then this could be the problem. Bass frequencies travel further than higher frequencies due to their longer wavelength and will also be transmitted through any solid objects the speaker is in contact with. The solution is to mount your sub on a piece of foam to provide some damping.
Also if your sub has a port (a hole) on the back or side this needs to have a good 3 or 4 inches clearance from nearby walls or panels.
Finally the speaker cone itself needs to have a clear path to push sound energy into the room, if this path is blocked by furniture (some people like to hide them under tables) then it may make that furniture vibrate.
Nov 26, 2007 | JBL SCS200.7 Home Cinema Package System
Home theatre subwoofer
Sounds like you have a loose signal lead. Check to see if this cab be tightened if not replace the cable as this could be the cause of the problem. Over time the leads/plugs do loosen especially on subs as they vibrate so much. If it's not this then it's probably something internal to which I am reluctant to advise you on looking at yourself unless you are pretty proficient with electronics :P
Nov 08, 2007 | Jensen XS-1010 Car Subwoofer
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
119 people viewed this question
 Grubhead
Grubhead
