Question about Pelco Cameras
I am looking for a wiring diagram for a Pelco TV10AC zoom lens.
Zoom yellow
Focus Green
Common Black
Common Red
video (aiv) AUTO IRIS lens back side
1 = Red wire VCC (+9 to +18 VDC) _____
4 = Black wire Ground p ' '
3 = White wire Video Signal L ' 2 1 '
u ' * * '
g ' '
1 = red ' 4 3 '
2 = nc ' * * '
3 = white \ /
4 = black \ /
\__/
Posted on Mar 29, 2011
Wiring for es30cbw35-5n
The WEB
PDF]pelco es30cbw35 2n security cameras owners manual
www.manualeak.com/.../pelco-es30cbw35-2n-security-cameras-owners-...
Another way of pelco es30cbw35 2n security cameras owners manual is a utilized as a .... owners manual pdf rtf, 2003 audi a4 symphony radio wiring diagram .
Aug 04, 2015 | Home Security
Wiring diagram
I hope you can zoom in on this pic. I hope also you were wanting wiring diagram for your car stereo. If not just let me know & I'll do my best to find what you are looking for. Have a great day. 5_14_2013_2_06_23_pm.png
May 11, 2013 | Car Audio & Video
Problem setting up Network Cameras
on the cameras them self there should be a adress and baud rate setting this should be the same as what you have on the software. also the cable that you have going back to your ethernet panel cannot be by any electric lighting or anything like that and check and make sure that the connetors that plug in to the panel have the right color code. you need to look for the straight through wiring diagram 568b. hope this helps.
Nov 11, 2009 | Pelco DX3100 Series 8-Channel 120GB DVR
Won't zoom out
This seems to be a common issue.
Mine was stuck at what seemed like max optical zoom.
When i would look in the lens I could not see the zoom lens. If you can not see your zoom lens and the optical zoom seems stuck I bet your camera has the same STUPID issue that mine has.
It was out of warranty and I figured I had nothing to loose so I took it apart to see if I could fix it, turns out I was able to fix it just by taking it apart and putting it back together!
Taking it apart is simple enough for the average handy man, if you do not have confidence that you can take it apart then do not attempt this repair.
Take off the bottom cover.
Take off the Hard drive cover
Now remove the three screws under the hard drive that hold the drive's plastic housing in.
Remove the screw that is right under the record button, now the drive house should be loose.
Disconnect drive cable from board and remove drive and housing.
Take off the plastic piece that has the zoom button, be sure to gently disconnect the wire.
Remove rear piece.
That screw marked with an arrow on the bottom, do not remove it!
Now remove the thin metal piece to expose the flat cable.
disconnect flat cable from board
gently flex it out of the way so you can disconnect the cable behind it.
Once you have both disconnected remove the circuit board.
unplug the flat cable on the back side.
Now remove the front piece.
At this point you are nearly there!
Now remove the metal housing that holds the lens assembly.
Once removed remove the lens assembly by removing the three screws.
If you thought that was bad, this next part will scare you.
Make sure you are in a very clean room with no fans blowing.
Remove the CCD from the rear of the lens assembly by removing the two screws on the back that hold it in place.
Remove the foam and square lens piece that were behind the CCD.
On the side of the assembly is a screw that holds the top cover in, remove it and gently pry off the top cover.
looking inside you will find the following:
on the CCD side is the focus lens.
in the middle is the shutter
On the side farthest from the CCD is a zoom lens.
On mine the zoom lens was not close to the shutter
If your zoom lens is not close to the shutter then you likely have the same problem as I had and you can fix yours!
If not, you likely have some other issue :-(
To fix mine I turned it over and I loosened the screws that held the motor and shaft for the zoom lens.
Then I slid the zoom lens as far back as it would go towards the shutter.
Then tightened the zoom lens motor and shaft mount.
Put it all back together, installed battery and bingo it's working again!
Why did this fix the problem?
Well there is a little sensor that tells the camera that the zoom lens is near the shutter.
Each time you turn off the camera it always puts the lens in that "home" position.
If the camera is turned on when the zoom lens is not in this "home" position then the camera seems to assume the zoom is broken and you end up with the infamous JVC stuck zoom issue.
My guess is this problem is caused by any of the following:
1. Removing the battery while the camera is turned on
2. Dropping the camera while it is on or off
3. Battery going dead while camera is in use
Final thoughts before you get started:
1. If you are not good at working with tiny parts or electronics, I wish you luck because you will need it. Might be better off printing these instructions and taking them with you to a repair facility and paying someone more familiar with this sort of work to fix it for you.
2. The ribbon cables are removed easily. Each one has a clamp that rotates to release the ribbon. Some rotate towards the ribbon to release, others work the opposite. It is quite obvious looking at them which ones go what way.
--e100
Sep 03, 2008 | JVC Everio GZ-MG21 Camcorder
Installing a pelco ptz camera using my old controller
pelco cctv ptz doec not moving can you give me a solution?thanks a lot.
Aug 18, 2008 | Cameras
Authorized Service Rep in Philadelphia, PA ??
The only authorized repair service center is the one in Clovis, CA.....Pelco shut down the one in Orangeburg, NY...The one in Clovis is 3500 Pelco Way Clovis, CA 93612 and their phone number is 1-800-289-9100....ask for the service and repair department.....the do free quotes on all repairs...Good Luck and let me know if this helped
cbinny1
Mar 04, 2008 | Pelco Computers & Internet
The Zoom ring is stuck between 24 mm and aprox 40 mm. What can I do to fix this? Any hints would be appreciated. Charlie
My lens started catching as I zoomed in and out and would not go wider than ~24mm. The problem is one or more of the screws holding the zoom mechanism comes loose and jams. Follow this link for the fix; took me ~20 min to repair (I went very slowly)! Much easier than taking it apart from the rear.
http://photo.net/nikon-camera-forum/00Pegi
Good luck...
-David
Feb 16, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Diagram of parts in sigma 28-80mm zoom lens
Hi The front lens just screws in and no locking ring
Nov 18, 2007 | Sigma 28-80mm Mini Zoom Macro Lens
Zoom error
look for a tiny pinhole and insert a pin while powered up to reset...if this does not work, if you get to the point to see any electric motor, then apply a battery powered set of jumper wires to the motor to manually run the zoom back and forth. start with one battery (1.5 volts) only!
May 27, 2007 | Fuji FinePix 6900 Zoom Digital Camera
Cameras Logo
216 people viewed this question
Top Pelco Cameras Experts
Are you a Pelco Camera Expert? Answer questions, earn points and help others
