Question about Siemens Fujitsu SCENIC D (D810E-E8F) PC Desktop
The speakers does not work via monitor - Siemens Fujitsu SCENIC D (D810E-E8F) PC Desktop
  • 67 Answers
Monitor speaker need to check with other audio device
Posted on Jan 04, 2011
Speaker in/speaker out not working
Are you feeding the monitor via an HDMI connection? HDMI carries digital audio as well as digital video signals. If using DVI or VGA to connect it to your PC, there is no audio being fed to the monitor, so nothing can come out, unless you have a separate audio cable running to the monitor as well from the computer :o)
Nov 11, 2013 | Dell ST2420L 24 inch LCD Monitor
Why is the sound not working on my acer screen
How do you have the screen plugged in?
If via HDMI, audio should go to your screen, but you may need to output to speakers (that is, if your monitor does not have built-in speakers).
If indeed outputting via HDMI, make sure your computer KNOWS it's supposed to output audio through the HDMI port as well as the video.
Finally, you might just need to plug speakers/headphones into the monitor - most have an audio jack on the underside, by the stand.
May 06, 2011 | Acer P221W LCD Monitor
I have got a hyundai monitor imagequest l50s , but the speakers won"t work
If the speakers are built in, check that the volume on the speakers via OSD is not turned all the way down or off. Many monitors that have speakers have an audio amplifier as the sound output from computers is very low and requires a powered speaker system in most cases. They are designed to operate head phones only now a days.
Jim
Mar 05, 2011 | Hyundai ImageQuest L50S 15" LCD Monitor
Sound not playing correctly via the speakers on the monitor Back ground music but no voice
sounds to me like you may have the monitor speakers connected to the wrong port. It typically connects to the computers Green speaker jack. If it is connected properly, look in the control panel for audio/ speaker properties, change the speaker configuration to stereo speakers, instead of 5.1 speakers. you are likely hearing the rear channel of 5 speaker setup at the moment.
Aug 29, 2010 | NEC MultiSync LCD1735NXM (Silver, Grey)...
The Sound of the Monitor is not working.
Check cable connections between the monitor and the sound card/motherboard output, you could unadventedly dislodged it, check the monitor speaker volume control on the monitor menu. If all else fails connect the headphone input directly to the PC case front or back sound output - much better than via the monitor anyway - shorter pathway makes better sound, last but not least: use a better set of speakers - monitor speakers ****
Mar 06, 2010 | Computers & Internet
I purchased a X2gen 15'' monitor and can not make the speakers work. Do I just need to purchase a ''y'' audio connector and plug it into the audio jacks for left and right speakers? bjsworld
If there are ports to plug a cable into, you need to connect the monitor speakers to your PC via those ports. A Y cable would probably do it. The standard monitor cable does not carry sound to speakers in a monitor.
Jan 28, 2010 | Computers & Internet
Speaker connection for LG W2053TX monitor
This model of monitor does not come with speakers. In fact very monitors have speakers. You will need separate speakers for sound. Some monitors do come with external speakers which hook onto the monitor at the sides but they are still connected to the PC via a lead with a 2.5mm stereo plug into the sound output..
Dec 12, 2009 | Computers & Internet
Bose Companion 2 Speakers won't work with Sony Vio Laptop
You don't write which operating system you use, but generally you should be able to choose where the sound output goes in the Sound Properties in Control Panel.
If however Sony decided to put some special software that does the thinking for you, and directs the sound output via the HDMI when connected, then you have to dig deeper...
Oct 30, 2009 | Sony Audio Players & Recorders
I have the compaq FP 7317 monitor and the speakers on it dont seem to work how can i fix it? i tryed plugging in other speakers but those work either
Make sure that your soundcard is properly installed as are it's drivers. Check to see that sound is not muted. This can be done via the speaker icon in the system tray or from sound in control panel.
Aug 12, 2009 | Compaq FP 7317 17" LCD Monitor
Cant get speakers on my monitor to work after I unhooked external
IF you have xp go to control panel/sound,speech and audio. You will see a drop down choice that says change speaker settings. Click on this. Then under the tab that says speaker settings hit advanced. Then select the sound scheme that says monitor with stereo speakers and apply this. Assuming you still have a functioning sound driver this should return it to the monitor speakers. Hope this helps.
Mar 29, 2009 | HP (400745-001) Sound Card
Siemens Fujitsu SCENIC D (D810E-E8F) PC Desktop Logo
157 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
