Question about ASUS P5PE-VM Motherboard
My unit automatically shut down when I turn it on
  • 75 Answers
There are a number of possible reasons for this. Most common in my experience is a short in an attached device. I suggest stripping the mother board down to nothing but a power supply and your processor/cpu cooler. see if you can get the board to power up and remain online.
Have you done any overclocking on this system?
Has it ever worked?
Thanks
Dustin
Posted on Jan 04, 2011
Samsung ht-f9750w blur-ray 7.1 home theater came up an error Protection then shut down automatically.
The unit has DC Offset, meaning a damaged amplifier. This issue will not allow to unit to turn until the damaged is repaired.
If you are interested in having your Samsung repaired, please look to my website at audioserviceclinic.com. Thank you.
Aug 08, 2015 | Samsung Audio Players & Recorders
Panasonic VCR shuts off as soon as we turn it on.
Not knowing model I will explain:
All VCR's have when turned on a mechanism that cycles in the unit-testing the loading/unloading mechanism----It will shut down instantly if a problem= broken belt, jammed or damaged mechanism etc.
Someone will need to open the unit and LOOK at the tray and loading mechanism---slipping or broken belt etc.
SD TECH
Aug 27, 2012 | Panasonic Televison & Video
Why does our VCR automatically shuts off when we turn it on?
SD TECH
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
What does f61 mean?
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 16, 2011 | Panasonic SC-AK18 CD Shelf System
Shuts down not allowing Windows XP to start
If the Computer shuts down automatically, then the issue might usually be due to the overheating issues.
The overheating issues develop, if the Cooling Fan in the Computer is malfunctioning.
The Processors are designed to shut down automatically, if there are any overheating issues.
For such issues, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan should resolve the issue.
Hope this helps.
Jul 07, 2010 | Toshiba Satellite A105 Notebook
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
ASUS P5PE-VM Motherboard Logo
24 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
