Toys Logo
Posted on Jan 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get a replacment boiler for mantua 4-4-2 atlantic locomotive?
Anonymous
Level 3:
Genius:
  • Master 1,196 Answers
  • Posted on Jan 04, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1196
Questions
0
Helped
209538
Points
3559
You can check ereplacementparts.com or ebay.com for the replacement broiler needed.
How do I remove the shell on my Bachmann 51114 4-4-0 steam engine . I want to clean the gears and lube the axles. also replace the traction tires.
They have their own forums and the information is there
Print Page - Baldwin Modern 4-4-0 Disassembly - Bachmann ...
https://www.bachmanntrains.com > home-usa > board
Apr 2, 2017 - After looking at the parts breakdown I am attempting to remove the boiler and ... (I ran across this same issue with my 2-8-0 today as well)
Missing: 51114 ‎' Must include: 51114
how do i remove the shell on my bachmann daylight 4-8-4? a ...
https://cs.trains.com > mrr
Feb 18, 2016 - Model Railroader is the world's largest magazine on model trains and model railroad layouts. We feature beginner and advanced help on all ...
28 posts · so today is my 23rd birthday. i am now the proud owner of a bachmann 4-8-4 4446. so this model ...
Mar 03, 2022 • Toys
I have a Bachman's class 4MT locomotive DCC ready. I have a Bachman's 36-553 decoder but there is not enough room under the boiler casing to fit the decoder.
You may have to go to a Digitrax N /HO scale decoder for it to fit. The decoder handles motor functions OK but a sound N scale has very low volume as the speaker is very small. I have done this a few times with good results. Or put the decoder in the tender and run the 30ga wires to the engine
How is Bachmann's Blue Comet's locomotive powered. We were just given a set. The tender & each car take 1 9v battery but I know there must be more.
The backhead on the boiler inside the cab of the locomotive opens up and you install cell batteries into the boiler to run the locomotive..
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Locomotive no longer smokes
If the smoke unit was working, and no longer does, it may be burned out. Did you turn the unit off after running it out of fluid? If not, it will need to be replaced. The switch is behind the smokke box door on the front of the boiler. I'm not sure if the smoke unit is a warranty replacement part, but a check with Bachmann Parts & Services & they will give you an answer.
http://www.bachmanntrains.com/home-usa/prod_serv.php
Your Locomotive is commonly called the Bumble Bee.
Cant find where the batteries go in train
in the cab of the locomotive, you will see the backhead of the boiler.
you should be able to open it and slip the batteries into the boiler.
Cannot figure out the assembly of Mantua IPK170 bedframe
If you go to www.Mantua.com you may be able to download instructions on assembly of your bed frame. If not try emailing customer support and ask them to send you a link to a download for assembling your bed frame or, perhaps they can send you the attachment of a assembly instructions .Be sure to include what you want instructions for.
Jul 31, 2010 • Mantua Toys
Fitting exhaust for Atlantic 500
2001 (I think it uses the Vespa ET-4 engine). Are there any other exhausts besides the Aprilia one that would fit without welding etc? Also what gasket do I have to get with it? Any online shops you can recommend for the parts? Just want to take the lot to the dealer and have them fit it - but the official parts are way too pricy. Please help! ,There's a Sito Plus ET4 exhaust that fits the atlantic costs around $170. I purchased mine but haven't put it on yet (I bought it during a winter sale), so I'm not sure about gaskets. From other scooter posts I've read, a lot of ET4 owners replaced their stock pipes w/ it. I bought mine from Scooterworks.com... Anything would look better than the dull black pipe the atlantic comes with,,,
Top Mantua Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Mantua Toy Expert? Answer questions, earn points and help others
