I have a dell E510 desktop. It will not turn on. However, the green light on the motherboard is lite up. I tried to replace the CMOS, reset the memory sticks and even replaced the PSU. still nothing working. Any help would be greatly appreciated
  • 58 Answers
I suggest you to remove cmos battery ram module and cpu together and leave them for a couple of hours then put them back also you can try to clean ram with a pencil rubber. other thing may be helpfull try to find cmos jumber and reset the bios not to remove battery
Posted on Jan 04, 2011
Dell E510 Diagnostic light 1 is blinking, 2 is out, and 3 & 4 are solid green
those are diagnostic lights which tell a dell tech how to analyze the condition of the motherboard if all four lights are on that indicates a failure more which usually suggest cpu replacement
is your computer doing something odd?
May 24, 2012 | Dell Dimension™ E510 PC Desktop
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
E510 can not start,only the green light on motherboard is good.
TRY TO OPEN THE COVER OF THE DESKTOP KEEPIT OFF WHEN DOING IT BE OVERCAREFUL TRY TO REMOVE THE MEMORY CIRCUIT CLEAN IT PROPERLY THEN TRY TO FIT IT THEN ON THE PC IF IT GET ON ITS FINE OTHERWISE THERE WOULD BE A SYSTEMBOARD PROBLEM CALL A TECHINICAN
Nov 13, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
I need to reset a bios passwoerd on my dell dinention e510 desktop
There are 2 methods doing that (I assume you forgot this password).
1. Hardware (easiest one):
a. Switch off power (plug out power cable or switch off power supply)
b. open your PC box
c. locate CMOS battery on motherboard (the largest part)
it will look exactly like that (round)
d. Just take it out and wait 30 seconds
e. plug it in. BIOS data will reset (password as well)
#2. Sofware
You may use !BIOS to reset bios password. Download + instructions you will find on this website.
Leave rate if I helped you, thanks!!
Cheers,
Mike
May 09, 2010 | Dell Dimension E510 PC Desktop
Dell Dimension E510 will not turn on
It could be.
When you switch on after it has been turned off for a while look at the fan on the PSU as you switch on.
If it spins or tries to spin for a very short time then I would indeed suspect the psu.
If however the psu fan does spin for longer and you can hear any beeps then that would be an indication of a different problem.
Should that be the case then check here.
http://www.computerhope.com/beep.htm
or here
http://www.pchell.com/hardware/beepcodes.shtml
  • If you found this information useful please click
Aug 13, 2009 | Dell Dimension E510 PC Desktop
I dont know the system password `
user name administrator type and anter the systems
Aug 03, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
I have a Dell E510 that will not boot up. It has power and I get error codes 3 and 4. I have reseated the memory and replaced the memory to new memory and tested them one by one in the first slot. The...
Ok what you might try is get a new hard drive and install windows on there and see what happens. Also if you are able to before you try a new hard drive you should do a system restore and restore it back to the day that windows was installed.
Jun 18, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell E510 Freezes during Bios Load
u haveto reset your bios wit juper settings it is near cmos set in it 2-3 position then again in 1-2 position .
ten clear all dust from circuit then reaatch all calwe and connectors.
Jan 18, 2009 | Dell Dimension E510 PC Desktop
Dell E510 Memory
One thing worth trying is taking out the cmos battery (only do this if you are confident you know what you are doing on a motherboard). leave the battery out for at least a couple of minutes and then reinstall the battery (ideally with a new one). restart and you may find you have cured the problem and that your old memory was fine. If this doesn't appear to help (definitely replace the battery even if you think it is fairly new)and jump the CLR CMOS pins. (ask again if you need help on this). second to try is see if you can update the bios drivers from the dell site onto a disk on another machine - use as a boot disk and see what you get. after that i would suspect the power pack, there is no real way to test this without connecting it to another motherboard and seeing if it is fine. alternative would be to just replace it with an equivalent unit, they are not too costly. After this i would suspect major motherboard or bios damage, which may be fixable but is usually cheaper to replace the whole board if you have inserted the wrong type(frequency/size/combination) of memory sets into the board it can often cause this sort of trouble, and often a CMOS clr and reset can solve the problem Please let me know if you need talking through the process - (it is not too complicated, but you can cause damage if you do not know what you are doing) Hope this helps :)
Mar 08, 2007 | Dell Dimension E510 PC Desktop
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
