Question about Samsung Televison & Video
Samsung 46" LCD TV Model: LA46F81B Problem: When
freetek
  • 5568 Answers
SOURCE: No picture on a Westinghouse lcd tv model ltv-20v4
The simplest problem would be the failure of the backlight.
In case you don't already know it, there is one, and they may or may not last forever.
Also, there is an extra power supply to produce the high voltage the lamp needs to fire that may have failed.
Sometimes, you can look at the screen from an angle to see if there is any sign of movement.
If you can see program material causing a change in the faint image, then you can be pretty sure it is one of the two problems mentioned.
Posted on Sep 01, 2008
  • 53 Answers
SOURCE: Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Posted on Mar 20, 2009
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
  • 541 Answers
SOURCE: SAMSUMG 46'' LCD TV MODEL LN46A530P1FXZA PROLEM
Check for bad capacitors in the power supply. The capacitors will be bulged on top. Typically there will be 3 or 4 caps with this problem. Thanks for using fixya.
Posted on Jan 23, 2010
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Sony KDL-46XBR4 46 in. LCD flashing light. Light flashes red 8 times pauses
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC. Try this link too.
Dec 20, 2013 | Sony KDL-46XBR4 46 in. LCD Television
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
My 46" Samsung LCD 630 works perfectly until a
Until a ?
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 18, 2017 | Samsung LN46A630 LCD TV
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Red light flashes bottom right and tv will not come on just makes clicking sound
Samsung TVs and computer monitors are notorious for bad power. You'll need to have TV serviced.
Jun 17, 2009 | Samsung LN-T4665F 46 in. LCD Television
No Picture on Samsung LT-P468W
You have to open up the tv and look at the power board. If there are any capacitors bulging or misshaped replace them by soldering.
Aug 13, 2008 | Samsung LT-P468W 46 in. HDTV LCD...
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sony 46"lcd tv x series
Can you please post the exact model number from the back. The 10 blinks is an indicator of the probelm circuit, but is specific to the model number. I can provide more details once I have the model.
Thanks,
Dan
Mar 19, 2008 | Televison & Video
Televison & Video Logo
91 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
