Question about Ricoh Aficio 2018D All-In-One Laser Printer
Error 500 ricoh 2018 - Ricoh Aficio 2018D All-In-One Laser Printer
    President:
  • Ricoh Master
  • 2,246 Answers
Sc 500 is the main motor error. replace the main motor at the back. it will solve the problem
Posted on Jan 04, 2011
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Error sc 553
error SC533 is a problem in the fuser check/replace thermistors and check thermostat/fuse for broken circuits. then check the fuser if it is heating or hot then check the contact of the fuser and the machine there might be a loose contact on the fuser and connector of the machine. after checking it reset the machine by the way is this SC 533 for the aficio 2018 or other model?
Sep 16, 2011 | Ricoh Aficio 2018 Copier
My Ricoh 1018D is showing an sc500 error code. what could be wrong?
SC:500 Main motor lock
Symptom: A main motor lock signal is not detected for more than 7 consecutive
checks (700 ms) after the main motor starts to rotate, or the lock signal is not
detected for more than 7 consecutive checks during rotation after the last signal.
Possible Cause:
• Too much load on the drive mechanism
• Main motor defective
IMPORTANT: From my experience I tell you disassemble the image unit and check for worn gears. If not replace the main motor.
Feb 02, 2011 | Ricoh Aficio 2018 Copier
Ricoh Aficio 2018 ink rubs off paper too easily
Your corona wire is not function properly ... dirty or broken ... and/or the heater is not up to par.
Replace the corona and the heater roll to fix this problem.
Jun 22, 2010 | Ricoh Aficio 2018 Copier
Ricoh Aficio 2018 shows functional error 670
SC670 is an engine start error. If it only happens once, it could just be a hiccup in the system -- reboot the copier and see if it goes away.
If the error recurs, try reseating the connectors on the copier's main boards. If that doesn't work, either the engine board or the controller board will probably need to be replaced.
Jun 17, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018D All-In-One Laser Printer Logo
304 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
