Question about HP Compaq Presario SR1115CL PC Desktop
My system says K boot failure, insert system disc and press enter. I am wondering if a cable is unplugged inside? I had the pc open to install a wireless card? Does K refer to a specific drive that I can check the connections on?
    President:
  • HP Master
  • 2,246 Answers
Reinstall your pc, your system was error
Posted on Jan 04, 2011
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
Disc boot failure, insert system disc and press enter, I have no disc what to do?
that was mean the hardisk failed to boot, tried to replaced the IDE or sata gate in the hardisk and reboot the system.
Oct 12, 2012 | Evesham Evolution PC Desktop
I have a HP Pavilion Elite m 9357c that willnot boot up. The screen goes black and says Disk Boot Failure,Insert system Disk and press enter
If it happens that you are prompted by the following error message "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER", "No system disk", it means that the computer did not find the operating system to start (boot).
Causes:
A diskette or CD has remained in the drive
Check out if any diskettes, CD-ROM or DVD-ROM are present in respective drives, remove them and restart your computer
The boot sequence is incorrect BIOS
Enter the BIOS setup of your computer and edit the boot (boot sequence) so that the computer starts primarily on drive C:
A new hard drive was installed
In the case that a new hard drive has been installed, this message is quite normal.
Just insert the correct CD to install the system (usually Windows), then restart, while making sure the CD-ROM is first in the defined in the BIOS setup as first boot sequence.
The hard drive is unplugged
Open the system unit and check that power cable of the hard drive is properly connected.
Corrupted system files
It may happens that some system files needed to boot the computer have been deleted /damaged or that the boot sector of the disc is damaged.
To determine this, start the computer with a system disk or CD-ROM installation of Windows (via the Recovery Console), and once started, type Dir C: to check if the contents of drive C: are accessible. If its ok then the problem comes from missing or damaged files, then you just have to run the command:
fdisk /mbr
sys c:
Note that before any restoration of the boot sector with the command fdisk / mbr, (supposing that there is a virus), it is recommended to use an antivirus running under DOS, such as
f-prot.
http://support.microsoft.com/kb/166454/en-us
http://support.microsoft.com/kb/69013/en-us
Damaged disk
If the hard disk or a partition is damaged:
If it detected in the BIOS setup, there is a chance that it is
not out of service.
If it is, try reinstalling the system through the installation CD, in order to reformat or recover the partition using a utility.
Feb 03, 2011 | HP Media Center m7260n (EG642AA) PC...
My presario sr1720nx says disc boot failure. insert system disc and press enter so i put in recovery disc 1 and it says no hard drive found press any key to continue im lost and very upset never backed up...
remove your cpu cover reove the molex conecter ie power connecter and refix them do the same with ide or sata cable the power connecter may be loose or ide connecter or sata cable may have fault
Sep 27, 2010 | HP Compaq Presario SR1720NX (EL435AA) PC...
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Hi. Well there are not any reason for this problem to appear. Done nothing regarding disk problem. Anyway when I boot the process stops with the black screen with "Verifying DMI Data...... Boot from...
Make sure you dont have a floppy in the floppy drive inserted.
Also if you have a jump drive installed, plz unplug it.
But if you little computer savy. Go to your bios and make the boot sequence to first boot the Hard Drive
May 24, 2009 | Foxconn G31MX-K socket LGA775 motherboard
I try to boot my computer from a windows 98 disc, but it won't lo
Hi matthewbugbe,
I think what that means is it does not recognize your hard drive. If you are trying to install Windows 98 you should format your drive first.
Mar 08, 2009 | Microsoft Windows 2000 for PC
When I start my Computer the On Screne message is Boot failure. Insert Boot Disc into A and Press any Key. I have tried to install Windows XP Pro but when the files are installed and i press enter,the...
It looks more like hard disk failure.
If your PC is still within the waranty period, kindly contact your PC vendor to fix the problem for you.
If the warranty period has already expired, please switch off your PC and remove all power sources and open up your CPU and check if the hard disk cables and the power supply is fine. Also check if there is any loose connection.
This should fix the problem, else please provide more details.
Jul 24, 2008 | Computers & Internet
Disc system failure error
U SHOULD SET HARDDISK AS U R 1 ST BOOT DEVICE.. I THINK THIS MAY SOLVE U R FROBLEM..
IF IT DONT HELP ,U. THEN..U CAN RE INSTALL WINDOWS..
best regards & best of luck..
Oct 12, 2007 | Intel Dot Station (INTC300AIO) PC Desktop
HP Compaq Presario SR1115CL PC Desktop Logo
112 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
