Question about Brother MFC-9440CN Laser Printer
My Brother MFC 9440CN has been leaking toner onto one side of each copy. Right now it's blue, earlier it was magenta. It also makes a full length irregular dent in the page on the same side. I've cleaned it inside & out, and replaced toner cartridges. I'm on the 2nd drum since purchase two years ago. Print copy is horrible. Now I'm getting a message to "Replace belt." Which problem do I tackle first, or should I just through it out and buy a new printer?
    President:
  • 2,246 Answers
Buy new printer
Posted on Jan 04, 2011
WHY DOES BROTHER PRINT PINK CHECK MARKS IN LEFT MARGIN?
NON-Technical answer...this machine has four drums(connected) and four toners. the magenta appears to be the problem ... I would first take out the magenta toner..make sure you have a cloth and something to catch the mess. see if anything (crum,dust bunny,paperclip,etc)is in that area. if it very dirty, replace the magenta first( using generic??). open plastic cover in front where the toner was seated and move the green bar back and forth .close that back up. test it. it gets expensive after this and you should call a tech. before you throw money at a problem.
Jun 06, 2014 | Brother MFC-9440CN Laser Printer
My mfc-9440cn prints a black line on the rigth side do you know what could that be? maybe needs new drum?
Hi there !
If you are self refilling the toner cartridge, the roller drum can be damage due to wear and tear. I need to replace new toner cartridge other i will getting wider and wider on both left and right of the paper.
Jan 13, 2011 | Brother MFC-9440CN Laser Printer
Waste toner full MFC 9840
I followed the instruction here to enpty the toner box (http://www.howtofixcomputers.com/forums/printers/brother-mfc-9440cn-waste-toner-box-reuse-288524.html) and I am no surgeon or even mechanically inclined, but it was very easy to do and worked without any problems!
Jan 08, 2011 | Brother MFC-9840CDW Laser Printer
I have a Brother MFC-9440CN. It has been sitting for a while and when I print the right side of the paper has a lot of specks. How do I clean the inside of the maching.
In the users manual, it has directions on how to run a cleaning sheet. Do this 5 times. If it does not correct the error, open the machine, remove the cartridges and inspect the carts and the drum unit for excessive toner. If one of the carts is leaking, replace it and run the clean procedure. If the carts are clean, the drum unit needs to be CAREFULLY blown off with deionized compressed air set to 35 psi.
Sep 29, 2010 | Brother MFC-9440CN Laser Printer
My yellow toner is out and the printer will not print in just black
The MFC-9440CN should be able to work even if one or more of the color cartridges are empty.
here's what you can do to print in black only.
1. Unplug the power to the MFC-9440CN
2. Clear the print queue on your computer so that there are no jobs waiting.
3. Right click on the MFC-9440CN printer icon and select "printing preferences"
4. Select "mono" as the color mode.
5. Turn the power back on for the printer.
Now when you print it will be in black only and it should work even if all 3 colored toner's are empty.
Thanks,
Pat
Mar 26, 2010 | Brother MFC-9440CN Laser Printer
My printer is not reproducing colours correctly,
I had this problem, but only when I used "Compatible" Toners. I do not have this problem when using "Original"s. Perhaps you are using Compatible Toners?
Jan 24, 2010 | Brother MFC-9440CN Laser Printer
Right side of every page has pink strip down page
Either your magenta cartridge is leaking out of the right corner or you have a defective magenta drum.
(maybe it got scratched when changing the cartridge?) If it's the magenta drum, you have to replace all the drums since they come in one unit. OEM part only.
Nov 20, 2009 | Brother MFC-9840CDW Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer Logo
743 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
