Question about Refrigerators
My hygena/schreiber tall intergrated larder fridge has stopped getting very cold. I thought the thermostat had stopped working .As insructed I turned it off waited 30 minutes and turned it back on. I could hear a soft humming noisewhich lasted a short time and then stopped. .Is the problem the compressor? Intermittently the fridge will get cold and then defrosts again Please can you advise me how to solve the problem? Thanking you Gill Thomas
    Habit-Forming:
    New Friend:
  • 117 Answers
Check where the compressor is and right next to the compressor should be a fan .Check to see if fan is running ,if it is then check the final type coil to make sure they are clean .
Sounds like your unit is shutting off on high head pressure
Posted on Jun 22, 2017
HVACRH20
  • 237 Answers
SOURCE: Fridge Stopped cooling
If the fan isn't running the "cold" won't make it to the refer section and the freezer won't get proper circulation of air. The "evaporator fan" must run when the compressor is running.
Posted on Jan 27, 2007
fanny
  • 146 Answers
SOURCE: Westinghouse Fridge Problem
Is the fan in the freezer running? You should be able to hear it. If not, that is your problem. Check the door light/fan switch or check if the fan has power to it when you press the door switch in by hand. If fan is running, you could have a defrost problem. The defrost timer or the defrost heater could be faulty.
Posted on Nov 04, 2007
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
  • 15 Answers
SOURCE: Hello FixYa The fridge light comes
Make sure the condenser fan is working and check the evaporator fan too!!
Posted on Aug 17, 2008
  • 1462 Answers
SOURCE: Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Posted on Sep 24, 2008
Bush fridge freezers
Order parts online through freezer parts supplier.
Oct 08, 2013 | Bush Freezers
Fridge is not getting cold even though the thermostat is at 5
Most friges take cool air from the freezer with a fan to cool the rest of the unit. I am not familar with your model but there should be a fan somewere in the back of your freezer. Also make sure you have space in back and to the sides of the fridge for air flow.
Jul 24, 2013 | Tecnik Built Under Larder Compact...
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
Larder fridge light on but not getting cold
Check condenser clean and warm. If too hot, may be fan not running, if too cool, compressor not pumping or short of gas
Aug 07, 2012 | Frigidaire Refrigerators
Fitted tall larder fridge freezing up on the back wall what is the problem and how do l sort.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Refrigerators
Larder fridge running far too cold
I was told that it ispossible for a snall pin in the thermostat to stick and that vigorously turning the knob up ad down a few times might well unstick the pin
Tried it and it worked!
Jan 03, 2009 | Refrigerators
Sep 23, 2008 | Liebherr Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
