Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
USB port broke off. Can I connect to something else to get the data off the drive? I cracked open the case and it's a barracuda 7200 but I don't recognize the pin connections. Please help? Thank you. Randi
  • lilbit811 Jan 07, 2011
    Thank you I will give that a try...
Yes just fixed mine. Went to radio shack bought a gigaware sata 3.5 external enclosure.
Took the harddrive out of old enclosure. pryed off external alluminum case to expose a panel that sticks out to the side where the broken usb plug went. Wiggled that off then placed in new enclosure fits good. secured with old screws. plugged it in and it works great. The new usb plug is much sturdier. The external case cost me about $40.00 and some change but Im glad i retreaved my data. I will never buy another seagate. Hope this helps...Alan
Posted on Jan 04, 2011
How do I read a barracuda 7200.12 1 TB drive? I need to get data off of it, not boot on it
Hi
The easiest way that I have found is to get a kit that allows you to power the drive from a separate wall socket and connect a data cable from the drive to a USB socket on the computer. Such a kit usually consists of four components:
A mains lead - wall socket to black box transformer
The black box transformer - has outlet 4 pin molar for IDE drives
A USB cable ending in unit for connecting to an IDE drive or SATA cable
A SATA cable for connecting to the SATA drive (your Barracuda 1Tb in this case)
The components can be seen on this Ebay site:-
USB 2 0 TO SATA IDE Cable for HDD with Power Converter Adapter UK
The one thing missing from this set up is a power conversion cable converting the molar 4 pin power connector to a SATA power connector. These can be a molar plug to go into the lead from the black box and either a single SATA power plug, or a double SATA power connector as shown here :
Molex to 2x SATA Power Dual Power Adaptor Splitter Cable Lead Hdd Cd DVD...
This option is inexpensive and offers great flexibility in the type of drives that can be connected to a USB port, 2.5 or 3.5 inch, SATA or IDE.
In your particular case you may be able to get a dock that connects to a power supply and a USB port, with an opening in the top to take a SATA drive. These tend to be more expensive and only suitable for SATA drives not IDE.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Seagate Barracuda 7200.12 1 TB 7200rpm...
FreeAgent Pro USB broken -- need data from Momentus drive
Momentus is a SATA drive, so you can put it in any PC that has SATA bus to access the drive.
If you can borrow a SATA to USB dock, you can put it in the dock and plug the dock to USB port on a computer to get your data out the drive.
One example for the USB dock is EZ-dock and you can search on Internet for the picture.
Apr 11, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Barracuda 7200 1TB spinning but not mounting
Man it sounds like it just died on you out of the blue... Maybe you had a power surge or something and you didn't know it.
Jun 30, 2012 | Iomega 1TB Desktop USB 2.0 Hard Drive
Mini-USB port has broken off from my 500 gb Seagate drive
Yeah you can probably just get the enclosure dissassembled. googling " how to disassemble seagate freeagent pro" pulled up a few links but if you're not comfortable doing that, try asking for help from local college computer lab geeks. I'm on the other side of the country from you so, can't help you much. The usb port that fell off was probably connected to the drive via an adapter so likely the hard drive itself is not damaged. Data recovery is much more expensive and I agree it isn't reasonable for this kind of problem.
Oct 05, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard drive failure segate barracuda 7200.9 it is two disks raid striped is there any way to remove data from disk or any way to connect them to another machine as a slave
how about scanning and trying to repair the sectors with hirens boot cd. There is a utility on it called hd regenerator or something like that http://www.hiren.info/pages/bootcd. I think you have to download this cd from piratebay first. There is no download from his website.
Sep 14, 2009 | Seagate Barracuda 7200.10 / 500GB / 7200 /...
I recently added a Seagate 500 GB external desktop drive to my Dell PC. It had only 18 GB on the C: drive, and I had gotten msgs that I was running out of disk storage. I installed the new drive thru...
Hi!
I think I would run the setup application and see if it helps. You're relying on the Windows drivers for the drive and who knows how well they work.
1. Turn the computer off completely.
2. Disconnect the USB drive and any other USB devices (for the time being).
3. Turn the computer back on, put the installation disk in and follow the instructions. Don't connect the USB drive until you are asked! Having it connected before asked may not allow the installation process to work as it should.
4. When everything is installed, hook your other USB devices back up and see what happens.
If this doesn't work, go to the Seagate site and try out their external HD troubleshooter.
Hope that helps! Remember to rate the solutions!
Aug 10, 2009 | Seagate USB 2.0 External Enclosure + 300GB...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Lacie hd problem
This is a pretty old thread, but I just figured out the work-around for my Lacie drive with the same symptoms. I took the Lacie case apart to find a pretty standard 3.5" Seagate Barracuda drive inside the case. If you pull the actual hard drive out of the box, you can either purchase a new external hard drive adapter box ($30-80) or install it into a tower computer. I installed it into an older G3 tower and it mounted right up. I decided it wasn't worth investing in a six year old hard drive, so I will be purchasing a new drive and pulling the data off the old one.
Mar 05, 2008 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
3.5" Dynex USB 2.0 External Enclosure + Seagate Barracuda 7200 RPM 500 GB HDD problem with computer recognizing the HDD and the enclosure
 If your running XP , go to control panal , Admin tools>Computer Management >Storage > Disk Management . Look for it there . If its there see if it says what file system . If none format it . If it isnt there then chack the jumper on the hard drive it self . It should be set to master or cable select .
Sep 03, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Windows XP not recognizing the hard drives
On the first drive that does sound DOA if you bought it new, is less than one year old and the warranty hasn?t been voided you should be able to get a refund from the manufacturer. Second drive, have you tried connecting the drive enclosure to another computer as a test? If it can?t read the drive data either I would suspect the enclosure electronics are faulty. Also have you tried the firewire interface yet? Semper Fi, are you active or former?
Apr 29, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
557 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
