Question about Onkyo HTR500 Receiver
Onkyo TX-SR308 crashes showing red STANDBY indicator flashing. Remove power and unit operates for about 30 seconds and crashes again. Occurs when running TUNER or HDMI HDTV with 5:1 surround. Any ideas?
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Hi! I have onkyo TX-SR308 and i surround problem.
You need to tell it you have surround speakers. Page 30.
The manual is available here...
http://www.onkyousa.com/model.cfm?m=TX-SR308&class=Receiver&p=d
Posted on Apr 28, 2010
Testimonial: "Thanks"
My onkyo tx-rz810 keeps going toDet.pretction mode how do I get it out of that mode
Does the display show you are in protect mode , or is a light indicating that? The unit automatically switches to standby when the
"Hardware" - "Power Management" - "Auto Standby"
setting in the Setup menu functions are set. The protective circuit function may have been activated.
If this has occurred, "AMP Diag Mode" appears on the
display when the unit is turned on again, and the unit
enters diagnostic mode. If the results of the diagnosis is
that there is no problem, the "AMP Diag Mode" display
disappears and you can use the unit normally again. If
"CHECK SP WIRE" appears on the display, the speaker
cables may be short-circuited. Make sure bare speaker
wires are not touching each other or the back panel of
the unit, then turn the unit on again. If "NG" is displayed,
immediately unplug the power cord from the wall outlet
and contact your dealer.
• The protective circuit function may have been activated
because the temperature of the unit rose abnormally.
If this happens, then the power will continue to turn off
after you have turned the unit on again. Make sure the
unit has plenty of space for ventilation around it, wait for
the unit to cool down sufficiently, and then try turning it
on again. This is out of your users manual.
General suggestions are to remove all speakers and speaker wiring with unit off. Turn on and see if problem has stopped. If not, let unit cool down if warm and try again later. If problem is still there it needs repair shop work. I fht problem went away, shut off power and connect one speaker at a time and testing. Keep adding speakers one at a time with power off and see if a bad speaker or wire set can be located
Aug 20, 2017 | Onkyo Audio Players & Recorders
How do I fix my onkyo tx-sr307
  • Check Fuses
  • Check for failed capacitor or resistor.
  • Check for open solder connection
The thermal cycling of these receivers can result in a failure of the solder joints around the components that get hot. The large capacitors if failing usually show signs of bulging or electrolyte leaking.
When the unit boots up out of standby the unit does a self check to confirm all power supplies are within determined limits. components such as resistors operate near failure limits. These parts are designed to fail similar to a fuse if the circuit is over loaded/heated.
Common problem is the required ventilation is restricted by covering the top etc preventing required air flow, overheats and a safety resistor fails.
Replace resistor with same type to retain saftey features.
Look for a burnt resistor. They are usually raised off of the PC board.
Hope this helps?
Sep 25, 2016 | Onkyo TX-SR307 A/V Receiver
How to reset RC-569M remote controller to factory defaults.
Not sure if it's the same, but for the Onkyo RC-799M controller the reset sequence is:
To reset the remote controller to its factory defaults,
while holding down RECEIVER, press and hold down
HOME until the remote indicator lights (about 3
seconds). Within 30 seconds, press RECEIVER
again.
Jan 05, 2015 | Onkyo Audio Players & Recorders
I got an Onkyo amp- TX-SR674, don't know why i turn on it but after 2 seconds, it will switch off and standby light is flashing, can many times. Please help
If the stand by red light starts blinking after 4 seconds of switching On it indicates an output short circuit. In all probability one of the Amplifiers output stage is defective and to prevent speaker damage the protection circuit is getting activated in 4 seconds. You will need professional help to fix this.
Sep 11, 2011 | Onkyo Audio Players & Recorders
I have an onkyo tx-sr308 and I am receiving only static or very low music on my right speaker channel. Please help
Switch to the other set of speaker outputs (move from A to B). If it continues, you have a repair issue...assuming it happens with all inputs. If it only happens with DVD, or CD, or Tuner, or whatever, but works fine with other components, it's a connection issue - unplugging and replugging, or replacing cables may correct.
If I recall correctly, that unit doesn't have a standard twist knob style balance control. If it does, turn the unit off and rotate it through it's full range several times, then recenter it and try listening to it again.
Jun 25, 2011 | Onkyo TX-SV444 Receiver
Apr 28, 2010 | Onkyo HTR500 Receiver
TR SR706 purchased 6 months ago. Unit powers on to
Onkyo USA Corporation
18 Park Way
Upper Saddle River, New Jersey 07458
For Dealer, Service, Order and all other Business Inquiries:
Tel: 201-785-2600
Fax: 201-785-2650
Hours:
M-F 9am-5pm ET
For Product Support Team Only:
1-800-229-1687
Hours:
M-F 9am-8pm | Sat-Sun 10am-4pm ET
Regional Service Center Dtr Technologies
2525 West 6th Aven
Denver, CO 80204
303-573-6288 (Tel)
Distance: 960.0 miles
show map
Please see below for local Service Centers.
Media Associates Inc.
612 National Ave.
Mountianview, CA 94043
650-968-2444 (Tel)
Distance: 33.6 miles
show map
http://www.onkyousa.com/loc_results.cfm
Oct 04, 2009 | Onkyo TX-SR501 Receiver
Onkyo tx-sr500; power goes out; standby light blinks
Remove all Wires form speakers
Power on
Push Video1 + StandBy /On
appears Clear on display
Dec 22, 2008 | Onkyo TX-SR501 Receiver
Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Sep 02, 2008 | Onkyo TX-DS838 Receiver
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Onkyo HTR500 Receiver Logo
355 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
