Send me the all color code of RJ 45, I/O Point color code
  • 516 Answers
Here is the standard network color coding
And these one is the cross over
Have a nice day!
Posted on Jan 04, 2011
  • 2,385 Answers
Hello
Do rate the solution if got help
  • 32,281 Answers
This WEB site will give you the color code for RJ45 connectors.
http://www.incentre.net/content/view/75/2/
Wirring cat5e wall plate
are you wiring for 486a or b config. send me a picture of the back of the rj 45 plug
Sep 16, 2012 | Genica Network Splitter 6 Cat5e RJ-45 (M)...
Building custom parallell adapter from j45 to b25 need colr code
If you mean DB25 connector you can try this:
RJ 45 Pin 1 to 5 Volt power
RJ 45 Pin 2 n/c
RJ 45 Pin 3 Gnd (DB Pins 18 -25)
RJ 45 Pin 4 n/c
RJ 45 Pin 5 to DB Pin 1
RJ 45 Pin 6 n/c
RJ 45 Pin 7 DB Pin 14
RJ 45 Pin 8 DB Pin 2
More info about DB-25 connector can be found here.
Jan 07, 2012 | Epson TM Office Equipment & Supplies
What jack does the Slingbox Ethernet cable hook into on a ATT 2wire modem? I have a choice of DSL or one like the phones are hooked into. It's not working now so I'm backing up each step, no matter...
Before you change anything - is this a new device you are hooking up or had this thing worked in the past? First thing to do is reboot everything starting with the modem and ending with the computer at the end of the line. Wait at least 30 seconds between each device. Review all the connections - everything plugged in where it should be? (this is of course your question - see more below).
Eithernet connections (plugs) are RJ-45. The RJ-45 looks like a RJ-11 (telephone jack) only bigger. Typically, the RJ-45 will not fit into the RJ-11 AND SHOULD NOT. Why? Your Cat 5 eithernet runs on very low voltage and signal (packet switching). If you succedssfully get the RJ-45 CAT 5 cable into the RJ-11 phone jack, when the phone rings, you will be sending 60 volts into your network. Can you spell "Do I smell smoke?" A RJ-11 will have up to 6 wires (one pair or two pair or three pair) in the jack and up to 6 'buds' on the RJ-11 plug. A RJ-45 will have 8 wires (in the jack) and 8 'buds' on the plug of your cat 5.
Your device may say DSL on the Cat 5 connection - count the wires inside or the jack.
There are other Cat 5 connection types, punch down and terminal screw types, I dont think you are talking about either.
On your AT&T modem, you should find a RJ-11 which will attach to a near by telephone jack and a RJ-45 for your Cat 5 cable. Your modem may also serve as a router and as such would have additional RJ-45 ports. I suspect you are using a separate router for your home network. As such, one of the ports on the router should be marked Internet or Upload or maybe it is a special color or is set aside from the other ports. That special port will be connected to your modem and your other computers will use the other, lesser ports.
Of course, you could call your service provider for clarification also.
Thank you for your question @ FixYa.com - I am sorry you are having this trouble and I hope I have helped you in some way. I hope you are able to get your system back up in short order.
If you are pleased with this response, please consider awarding the coveted 4 thumbs up to this response. Thank you
Aug 08, 2011 | 2wire Computers & Internet
How we join it with computer which LAN wire is use state or cross and proceser to joine
Your question is a little confusing ... chain saw networks?
I believe you want to know how to build a wired computer network ...
You will need special tools to do this including a RJ-45 crimp tool. You should use the highest quality ethernet, 'Cat 5', Cat 5e', wire available to you. On the ends you will install RJ-45 connectors (8 conductor 'plugs'. Choose and stick with one of the several color codes for placing the conductors into the RJ-45. Color code guide should come with your special tool. Make sure the ends are in proper order, trimed square and inserted fully into the connector before you crimp. Purchase a test tool to verify your work. Expect to pay $50.00 US or more for the testing tool. Cable, connectors, wire, router or switch and other hardware should be available where communications or electrial supplies are sold.
Thank you for your interest in FixYa.com
Aug 10, 2010 | Garden
I have a cable modem that doesn't want to accept the RJ-45 cable (I think that's what it is called.) I've tried several different quality cables with no luck. Strange problem. Any tips?
Some RJ 45 jack cable has fault so try with another RJ 45 jack cable .. Purchase new rj 45 jack cable from nearest computer shop. There must be 2 port on modem 1 for ADSL phone line cable and otthr for LAN ethernet port means RJ 45 jack port. Try with another rj 45 jack cable it should be connect.Make sure that LAN port of modem is not faulty means make sure pins on that port are not break. Let me know if you need further assistance. Thanks for using FixYa.
Jul 24, 2010 | Computers & Internet
How to attach cat 6 cable to rj-45 jack
Good day..You should have knowledge about the color coding for cat-6 cable termination. Its called "termination" computer term.if it is a straight-throw use this color code:RJ45 must face at you when you arrange the wire colors..WOrange,Orange,WGreen,Blue,WBlue,Green, WBrown,Brown..(W=White). Then use a Crimping Tool to crimp it.Flat that twisted wires before you insert to rj45. Hope you are okey with this. Ask me if problems occured. Mastergani
Mar 17, 2010 | Computers & Internet
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
I have a cat5e network cable i am hooking to rj45 flush mounted wall jack the wire color is not the same?
Either your wallmount is not correctly crimmped according to the standards or your cable is not correctly crimmped according to the standards. So its better you crimp the cable and fix the R.J 45 connector in the sequence given herewith.colour coding of the cable:-
1-oranage white
2-orange
3-White green
4-Blue
5- White blue
6-Green
7-White brown
8-Brown
The same Sequence should be at the wallmount and at the R.J 45 connector.
Apr 26, 2008 | Computers & Internet
Cat5e
Some testers do not test ALL the wires. Some will only test pair 1 and 2. You may want to use a DVM (Digital Voltmeter) set on the ohms function and check continuity on each of the eight wires from RJ-45 to RJ-45 connector or use a cable tester that will check all the wires. If you use a DVM check 1 to 1, 2 to 2 etc. for continuity. Good will read 0 ohms, open will read infinity or OL on some meters. 90% of all cable problems are poorly crimped or broken wires at the RJ-45 connector. It is difficult to be sure which end has the bad connection so you may need to change BOTH RJ-45 connectors. Do one, then check the cable, if it doesn't work, do the other one. It is a 50-50 shot. I prefer and encourage the rewiring color code using the EIA 568A standard. Starting at pin 1 the color code would be orange-white, orange, green-white, blue, blue-white, green, brown-white, brown. You don't have to do it that way, but you must make sure that the same color wire is on the same pin on each connector. If all else fails, you can go to you neighborhood computer shop for help in installing connectors. It takes a lot of practice to do it right. Hope this helps
Nov 30, 2005 | Honeywell Multimedia, Cat5e X2, RG6/U...
Computers & Internet Logo
1,767 people viewed this question
David Payne
David Payne
