Question about Toshiba Mini NB205-N313/P Netbook
Toshiba NB205, boots up then windows doesnt load, its just a black screen with a line in the upper left corner blinking... whats the problem
  • Rick Vill Jan 04, 2011
    I try removing all the accessories that are plug in, but my notebook doesnt have a DVD room. I can run on safe mode I can use F8...
  • Rick Vill Apr 13, 2011
    I just somewhat resolve the problem. Format i again. ths time i delete all partitions..
    install a new OS.
    It works. Up to now it is going fine...
    Brigadier General:
  • 8,909 Answers
Remove all accessories that are plugged in. LAN, USB and make sure the DVD drive is empty. Try again.
Posted on Jan 04, 2011
  • 2 more comments
  • specialistel Jan 05, 2011
    If you can run in Safe Mode there is possibly a conflict somewhere as Safe Mode doesn't load some drivers.
    Have you added anything just before you got this problem? If you did whilst in safe mode remove or uninstall the programme and that may fix your dilema.
    You can ask Windows to start on a Known Good Boot and that will take you back far enough to start properly without the problem, hopefully!
    Hope that helps.
  • Rick Vill Jan 06, 2011
    I reformat the pc.. after a day, it goes back again to its problem, the toshiba logo starts, I can access the boot menu, but after the logo on start up, the screen goes black, all I can see is the small line in the upper left corner that keeps onblinking...
    I cant go on safe mode, Nothing Happens on hitting F8 during boot...
  • specialistel Jan 06, 2011
    If you browse toshiba.com and download a fresh BIOS file on another pc if you can't download on this one save it on USB or floppy and install it.
    MAKE SURE IT IS SPECIFICALLY FOR YOUR NB205 otherwise it will never work again. While you are on the site give Toshiba a quick call, the number is on the web page, they are very heplful.
    I think you have a corrupted BIOS system and it can't move on from POST.
    As far as I can see there is a fresh updated BIOS . I am in UK but I looked for the US equivalent.
    29/06/10 BIOS update Toshiba OS independent 2.10-WIN World Wide
    If you can, download from your NB205 , it is so much easier!
    Hope that helps.
I replaced a cracked lcd screen on my wife's toshiba netbook NB205-N313/P. First let me describe what happened. The netbook fell and the screen cracked and I connected to an external monitor and had to...
Check the ribbon-cable between the motherboard and the LCD screen. It is not transmitting 100% of the video-information.
Be sure that it is not "crinkled", and that it is tightly connected at each end.
Sep 10, 2010 | Toshiba Mini NB205-N313/P Netbook
Black screen with blinking cursor upon start up
You don't say what Windows are you using.
Anyways, it seems like you have a corrupted BOOT problem.
On Windows Vista and Windows 7, you can insert your Windows installation CD, and choose the "Repair my pc" option.
Windows will do it automatically fro you, and you'll be up and running in a couple of minutes.
Dont forget to rate this answer if it helps.
Jul 18, 2010 | Dell Inspiron 531s Desktop Computer
Black screen and in the upper left corner there is a cursor theat is blinking ... and teat is all
It sounds like a problem loading the operating system. Try booting from an installation CD to see if anything comes up... if it loads from the CD, there could be a problem with your hard drive.
When it turns on, try entering the BIOS by pressing the correct key (usually DEL, F10, F12, or F2) Make sure that the boot device is set to your hard drive. If you do this and it loads with an error saying 'insert boot media' or 'boot device failed' you'll have to either try fixing your boot sector (which can get tricky, but I'll walk you through it if you really want to attempt it) or a much easier fix, reinstall the operating system.
May 04, 2009 | Computers & Internet
Black screen w/blinking cursor
So.. you can select safe mode? Or you turn it on and it is resuming into the blank screen?
If the latter. Unplug the power, pull the battery out for 20 seconds or so. Then put it all back together and try booting up.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba a75 s-206 problems helppppppppppppppp
Sounds like a bad hard drive to me. Take out the hard drive completely from the laptop and boot up with the windows xp cd and it should go past the blinking cursor. At that point you know you'll need another hard drive.
Mar 06, 2009 | Toshiba Satellite A75-S206 Notebook
Toshiba a75 s-206 cuts on than idk!!!!helpppppp!!!!!!!!!
If you put in a Windows CD does it boot into the cd menu?, does the black screen have the blinking white line at the top left corner?
Mar 05, 2009 | Toshiba Satellite A75-S206 Notebook
Toshiba won't boot
 You can boot from XP cd.
When prompted..press [R] this will launch recovery console.
Choose your windows installation (typically by pressing [1] press return..
When prompted for password type chkdsk /r
Press return..Windows will fix errors..type Exit and press return..
Let me know if that helps.
Jan 05, 2009 | Toshiba Tecra A8-S8314 Notebook
Recovery disks aren't Windows XP
Have you tried booting the laptop with the recovery disk already in the CD drive. If the disk doesnt register and start to spin press F12. Should give you option to boot from CD
Mar 07, 2008 | Toshiba Satellite 1135-S125 Notebook
Toshiba Mini NB205-N313/P Netbook Logo
197 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
