Question about Evga H55V (111CDE630TR) Motherboard
Got the new EVGA h55v mobo and having some install issues 1. the driver CD is a nightmare. The audio isn't installing properly, system registers the Realtek software but no hardware found. 2. the system is only registering 2.98 g of ram, when 2gig x2 installed any help?
    Problem Solver:
Kindly install patch KB 888111 & try......
Posted on Jan 04, 2011
EVGA H55V no sound
if you are referring to sound problems on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 28, 2012 | EVGA H55V Intel H55 micro ATX LGA1156 MB w...
I recently installed the EVGA GTX 460 2win and whenever I start to play a game on my computer it over heats and freezes the game. I have it connected to a ASUS Maximus IV Extreme motherboard inside a Cool...
Well if all of the fans are running on high, there shouldn't be a heat issue. I would install www.hmonitor.com and check and make sure heat is the actual issue. There could be a problem with the card itself and not necessarily caused by heat. You can try downloading the latest drivers for it.. but to me, if heat isn't the issue, the card probably has an issue and will need to be sent back to the manufacturer.
Jun 30, 2011 | Evga GeForce GTX 460 2Win 2GB GDDR5...
Evga H55v mobo issues with driver cd. Audio driver not installing, or rather HW not found after install. Also odd thing 4g of ram 2gx2 is only registering as 2.98g in system can you help?
If the driver cd is damaged then you should download audio drivers from here
http://www.evga.com/support/drivers/default.asp?switch=2
these drivers are probably going to be more up-to-date than what's on your CD anyway.
As for the RAM, the fact that it is registering at that specific amount makes me belive it's your operating system. 32-bit Windows operating systems do not utilize more than 3GB of RAM. If you get a 64-bit version (Windows XP Professional 64-bit for instance), it wil recognize all of your RAM. My brother has 4GB of RAM with Windows 7 Home Premium 32-bit and it sees that he has 4GB, but it says, "only 2.9GB utilized."
Jan 04, 2011 | Evga H55V (111CDE630TR) Motherboard
When i enter BIOS there is no way to set the boot device and just say after exit "install boot media and try again"
you can change a few settings in BIOS but as long as you can remember what changes you have made so if anything goes wrong you can restore bios to original settings
enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Dec 15, 2010 | Evga H55V (111CDE630TR) Motherboard
I have intel 845GVSR motherboard for P4 CPU and i am unable to install audio driver from Intel CD ROM So how to find & install audio driver?
Check your "BIOS" to see whether the audio device is enabled!!
For the Intel Mobo 845GVSR is a discontinued product by INTEL, and also check your CMOS CR2032 3V battery if it need to be replaced.
If you have the MOBO CD all the drivers are there but maybe the drivers are outdated.
Aug 12, 2010 | Computers & Internet
Canot work as properly audio driver
download new 1 from ur mobo site and unstall the previous and install new ones
Jan 14, 2010 | Microsoft Windows XP Professional for PC
System not powering up. Orange light coming on on evga 680i
check your hardsik or memory or other wise out your motherborad and download in check card your problem will be ko
im riaz ahmed brohi or email riazbrohi@gmail.com
Jan 27, 2009 | Evga nForce 680i SLI 775 TR...
Audio device not working in INTEL DG31PR board
2)Right Click My computer
3)Click properties
4)Select Hardware Tab
5)Click Device Manager
6)Click on the cross of System Devices
7)Right Click Microsoft UAA Bus driver for high definition Audio
8)Uninstall this (this is the problem making place and this might indicated as yellow color explanation mark before you uninstall it)Just uninstall it
9)Now install your newly downloaded drivers which i have asked you to download in the previous post.
10)System will ask to restart momentarily just follow the instructions and reassert .
Once all the installation and restarting are done your Audio will work with out any issues
Hope this will work and please let me know if my post able to fix ur problem.
Jul 28, 2008 | Intel DG31PR Motherboard
Audio problem
You need to install the correct driver for the sound device, because with win XP it can install a generic driver but it wont be working properly so if its a built sound on your MOBO you need to install driver for it from the MOBO setup CD.
May 10, 2008 | ASUS P4XP-X Motherboard
Sound card wont play root media files
Hi Hughdog
well, Biostar mobos are know for a lot issues, but depending too, on the OS, windows XP I presume, go on safe mode, and uninstall all audio drivers, and disable on the BIOS audio. then start the PC, and install the audio card. or if is a internal audio reenable again, redetec the drivers, and install them according to the CD and drivers. you should see the play device now and play music correctly.
good luck
Nov 19, 2007 | Computers & Internet
Evga H55V (111CDE630TR) Motherboard Logo
65 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Larry Rider
Larry Rider
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
