Question about Evga H55V (111CDE630TR) Motherboard
Evga H55v mobo issues with driver cd. Audio driver not installing, or rather HW not found after install. Also odd thing 4g of ram 2gx2 is only registering as 2.98g in system can you help?
    President:
  • 1,812 Answers
Drivers, once found need to be installed. Updating the drivers is a straightforward process, once you've been shown how to do it. Here we're going to look at installing drivers on Windows XP, though despite the differences, all the Windows versions have some common features so you should have no trouble figuring it out if you don't run XP.
Before we start there is one key thing we need check for the driver installation to go smoothly. Have you got the right driver? Don't be tempted to use the NT driver for an XP computer, nor is it worth using a driver that is designed for a model that is 'close but not quite the same' as your piece of hardware. If it's an external piece of hardware the model number etc are usually on there somewhere, either on top or maybe under the unit (where you'll often find the serial number), so check them. Also think about if you really need to change over your driver, particularly if you're considering something with a BETA in the title. Take this to mean unstable (beta means 'in testing' or unstable in computer jargon, sometimes the bugs aren't ironed out). I personally wouldn't consider a beta version driver if the driver I'm already using is doing the job.
Okay, let's assume that you've found the driver on the internet. The first thing you need to do is download it. As with all downloads you need to be able to find it again once you've downloaded it. It might be worth saving it to the desktop or even to a new folder you made called 'drivers'. Whatever works for you. The other option is that you have the driver on a floppy or CD Rom that came with the device - this is even easier: usually you just put it in the drive and follow the instructions. Drivers these days come in two distinct types. The easiest for the general user are those drivers that come as part of an executable file (one that ends with .exe). It's a good idea to scan the file with your virus scanner before doing anything, particularly if you've downloaded it. Once you've done that, just double click on the file name. It should do the rest - as always read any questions that it asks you. When it stops doing things, it's done. Often it will ask you to restart Windows for the change to take effect.
The other type isn't self-running like this and you'll need to install them manually. This isn't that hard however, and we'll go through it step by step. First you need to find the 'Device Manager'. If you don't know where this is then click on 'Start' (bottom left hand corner of the XP screen), then click 'Control Panel', click 'Performance and Maintenance' and then click on 'System'. You'll get a new window that has multiple tabs. Click on the tab called 'Hardware' and you'll see the device manager - click on the name to bring it up. This method is similar in all windows set ups, and all work from a command line instead - to do this go to 'Start', choose 'Run' and type devmgmt.msc in the box. This will also bring up the device manager.
From here it's pretty much following instructions. The device manager lists all the devices you have and you can double click on them to bring up a further window that lists the device properties. Click the tab for driver and you get all the details you need. You're looking at 'Update Driver', and normally you want to say no to the suggestion that Windows initiates a search via the Microsoft website because you already have the disc or file. Select no thanks, and click next. If you have the disc you choose it on the next screen, if you are looking for the file you've downloaded choose the option to select from a list (don't be put off by the word 'advanced'). The next screen again offers to search for you, again you decline the offer. Having chosen 'don't search' you can use the button on the right below the list (called 'have disc'). This opens a familiar dialogue just like all the windows file open boxes. Find the driver files where you stored them - you're looking for the file that ends .inf. Double click on it and wait for the installation to finish -don't interrupt the installation. You'll probably have noticed that in the device manager window there was an option to return to the previous driver. This is what you need to use if updating the driver seems to have made things worse. And that's it, you've installed the new driver.
Another eg for anothe driver not for its an example,just click on the link
http://www.zdnet.com/photos/step-by-step-how-to-install-broadcom-critical-driver-update/36959
http://news.softpedia.com/news/Install-Nvidia-Video-Drivers-and-AWN-on-Fedora-9-86757.shtml
Hope it will help you.
Posted on Jan 04, 2011
    Novelist:
  • 127 Answers
If the driver cd is damaged then you should download audio drivers from here
http://www.evga.com/support/drivers/default.asp?switch=2
these drivers are probably going to be more up-to-date than what's on your CD anyway.
As for the RAM, the fact that it is registering at that specific amount makes me belive it's your operating system. 32-bit Windows operating systems do not utilize more than 3GB of RAM. If you get a 64-bit version (Windows XP Professional 64-bit for instance), it wil recognize all of your RAM. My brother has 4GB of RAM with Windows 7 Home Premium 32-bit and it sees that he has 4GB, but it says, "only 2.9GB utilized."
  • Launam Jan 04, 2011
    Wow, that link I sent posted did not translate correctly, very sorry.
    If you put this link into your address bar
    Then select Mainboards in the left menu, EVGA H55 Series in the middle menu, Audio Drivers in the right menu, and then select continue on the bottom of the screen, you should be brought to the driver download page
EVGA H55V no sound
if you are referring to sound problems on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 28, 2012 | EVGA H55V Intel H55 micro ATX LGA1156 MB w...
My motherboard Biostar GF7100P need to program bios ,\r\nmy motherboard only turn on but do not action ( no picture in screen , no beep in motherboard ) my pci post code card show "FF" code in...
The first thing that I would do is check the MoBo's website and find a RAM compatibilty chart. Make sure that you Mobo doesnt have any know issues with your particular RAM. You may also check the RAM's website and look for compatible RAM for your MOBO. Rule this out first. The Sata F6 thing depends on the MOBO I think that most of the time you do have to f6 the drivers however on my ASUS this was not necsessay. My cut at this would be to take everything out of your system except for the few components that it requires to boot up and load the OS. RAM, Video Card, CD ROM, maybe the Floppy. Reformat your HD so that you can start over clean. Make sure that you have each cable plugged into the mobo correctly as well as the component. Reformat, then reload the OS. Start to load the system drivers one at the time rebooting after each is loaded. Pay attention to what you did last if the problem shows up again. This will probably point you to the issue. If every thing installs correctly without any problems then start putting the other hardware in one piece at the time loading the drivers andsoftware for each component then rebooting and ruung some stress test before moving to the next component.
Jan 19, 2011 | Biostar GF7100P-M7S Motherboard - v6.0,...
When i enter BIOS there is no way to set the boot device and just say after exit "install boot media and try again"
you can change a few settings in BIOS but as long as you can remember what changes you have made so if anything goes wrong you can restore bios to original settings
enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Dec 15, 2010 | Evga H55V (111CDE630TR) Motherboard
I just bout a evga geforce 9400gt 512mb pci I install the card into the pci slot.Turn on the computer and everthing works ok untill i install the drivers First of all when i install the drivers in regular...
The two biggest problems in XP is audio drivers and graphics drivers. From a long experience dealing with all kinds of graphics cards and drivers I would say that the driver you are installing is not correct for OS and your card. Not sure what you are using that makes you think it is but I believe it is not. If you are using a driver scanner software then beware. Your best bet is go to here..
http://www.nvidia.com/Download/index.aspx?lang=en-us
..this will give correct driver. This will probably fix BUT keep in mind that the pc beeping means hardware issue, so0o0oo not having the correct driver will also cause this, but usually not with a graphics card or it's driver. Usually this is mobo, ram, hd, etc.
Oct 23, 2009 | Computers & Internet
I bought a foxconn 45CMX/GMX mothebord. i install xp and then install drivers including sound drivers. evrythin was fine. but after 2days my machine doesnt gave me sound. so i try evry thin and finally...
Driver conflict most likely but you would have to test your physical hardware setup which may be the cause also. Odds are the driver is conflicting but given zero details on info that would give anyone a clue to help you I would say be more detailed on driver and audio hardware, wiring testing and beyond that try a different audio driver. If Vista it should solve for you so I assume XP which you do not state OS. XP can be a pain but if the driver works at all then odds are the correct one but you either are installing something that screws up and conflicts with that driver, or possibly your mobo or sound card is the root cause.
System did't found audio driver
my sound is not installed and i no have suporrt sound drive
Feb 01, 2009 | Altinex DRIVER/GLI CARD, 2-IN 2-OUT,...
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Problems with video card installation
uninstalled your RAM, turn on your PC for about 20 seconds, shut it down and reinstalling your RAM again...
Feb 14, 2008 | Computers & Internet
Sound card wont play root media files
Hi Hughdog
well, Biostar mobos are know for a lot issues, but depending too, on the OS, windows XP I presume, go on safe mode, and uninstall all audio drivers, and disable on the BIOS audio. then start the PC, and install the audio card. or if is a internal audio reenable again, redetec the drivers, and install them according to the CD and drivers. you should see the play device now and play music correctly.
good luck
Nov 19, 2007 | Computers & Internet
Evga H55V (111CDE630TR) Motherboard Logo
266 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Larry Rider
Larry Rider
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
