Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
E522B bottom freezer Ice maker not working. Red flashing light in rear of unit (Bottom left, rear of fridge), chilled water facility working normally.
The ice is just freezing in the bottom of the bin in a solid mass
Posted on Jan 06, 2011
  • ness0103 Jan 06, 2011
    Thanks, but actually; I found the root cause - the sensor wire had snapped - a design fault with the fridge. Seems F
  • kkim Mar 24, 2011
    Did it work after you rewired? I had the same problem. I noticed the snapped wire and I rewired (I think I did) but still not working. Is there anything else I need to do?
It won't dispense water and my control panel is lit up and flashing from item to item. Do I need to reset it? My husband pushed a lot of buttons to try to stop the ice maker and ever since then, it w
First, try unplugging the refrigerator for 5 minutes and then plug it back in. If the problem persists, you will need to replace the dispenser control module.
Apr 20, 2014 | Fisher and Paykel Active Smart E522B...
Continuous beeping
Either any door is not closed properly or door sensor is not working,its not sensing the door closed.Or the problem is no defrost.The defrost is causing over ice in fridge or freezer section.
Reset the refrigerator by disconnecting it from wall outlet for 12 hours,then reconnect and see if still the same problem is there.
On some cases its issue with fan not working.There are two fans,one in freezer section and one in fridge section.If either of the fan is not working the controls will flash.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Fisher and Paykel Active Smart E522B...
Fridge ice machine does not work, Model E522B, have turned machine off and then back on, cleaned ice machine and replaced it in proper place,
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Hope this helpout.....
Jul 28, 2010 | Fisher and Paykel Active Smart E522B...
Ice maker not working. Water is going to fridge,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
68tj
Dec 15, 2009 | Fisher and Paykel Active Smart E522B...
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
833 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
