Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Picture Too Large for Screen
The picture appears to be too big for the screen. TV station logos, names, etc. are chopped off.
Had the convergence feature repaired and since then have had this problem. I could not find a fix in the manual and was unable to find the problem while looking through the setup menu.
Please advise. Thank you
  • lesleynbarry Feb 21, 2009
    picture seems to be to large for screen, info. that scrolls across the bottom for some channels is chopped off.
  • MICHAEL MULLINS May 11, 2010
    Good Day, jhusinka;
    I will try to help but need to ask some questions if don't mind:
    1. Too large a picture, is the picture still bowed/ curved?
    2. Is pic just too big for screen?
    3. Is top and bottom (vertical-horizontal) too big?
    Let me know, big IRISH.
How did you fix it?
Posted on Aug 01, 2008
I have fixed the problem. Thank you for your response!
Posted on Jul 31, 2008
THE PICTURE IS WAY TOO LARGE. THE PEOPLE ON THE SCREEN FILL UP THE WHOLE SCREEN. IT USED TO LOOK NORMAL SIZE & ON CHOPPED WE USED TO BE ABLE TO WATCH ALL 4 CHEFS COOKING. NOW ALL WE SEE IS ONE CHE
Ad? Turn off "store" or "display" mode in menu. Look for picture size or "aspect" in menu. Remote should have button for "Size" or something.
Feb 12, 2014 | Vizio Televison & Video
I have a 52' big screen and the picture is shoing
Ur convergence is dead,go to ebay.com buy the convergence repair kit.Find out ur make and models,and manufactures of ur TV buy it.
All big projection DLP have this prob. one time or other every manufactures,Sony,Samsung,RCA,many others.
Aug 26, 2009 | Televison & Video
Picture on Olevia lcd is too large for screen.
If you are on a cable or dish box, check aspect setting from you box, TV needs to be 16-9 or full, set TV first then change setting on box.
Aug 09, 2009 | Olevia LT32HVM 32 in. LCD Television
Picture is too big for the screen
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
May 30, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Double picture & color problem
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
The picture is distorted. It appears as the picture is being drawn to the center of the screen.
This is a convergence problem. This can be either bad solder connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These are large black ICs attached to a heatsink.These should be marked STKxxx.
Keep me posted.
Dan
Sep 30, 2008 | Sony KP-65WS510 65" Rear Projection...
Sound but No Picture
Perhaps your remote is set to video recorder?  Try that first, and if no response, try calling up a menu on your TV and look for the Picture Settings.
Good Luck.
Nov 03, 2007 | LG 37LP1D 37 in. LCD Television
Picture slightly too big
To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset.
Sep 08, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
116 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
