Question about Cell Phones
Can I install a wireless headset with a remote handset lifter for Meridian M2550 attendant operator console to replace the original handset?
    Sergeant:
    Champion:
  • 202 Answers
Ya sure. why not.
Posted on Jan 04, 2011
HL-10 LIFTER DOSEN'T STAY UP AND SLIDES DOWN FREQUENTLY.
The internal gears on the Plantronics HL10 may be worn. You can take the handset receiver off hook and try manually raising up the lifter as far as it will go and then slowly pushing it back down into place, sometimes this will help to get it back working properly. If that doesn't work, you may need to replace the HL10 lifter. Below is a link where you can purchase a new lifter.
Plantronics HL10 Handset Lifter
Good luck from Headsets Direct!
Aug 30, 2011 | Plantronics CS70 Wireless Headset
When I attach a headset to the m2250 console it goes to night mode
Turn your handset connection with the dual plugs the other way!! You have them upside down!
Aug 30, 2011 | Nortel MERIDIAN M2250 ATTENDANT CONSOLE...
I cannot here the phone ringing from my CS55 headset or another call coming in.
You will need the Plantronics HL10 handset lifter in order to have the CS55 ring, indicating an incoming call. The HL10 also allows you to answer remotely on most phones and hang-up remotely.
Good Luck from Headsets Direct!
May 17, 2011 | Plantronics PL-CS55 Wireless Headset
Incoming call alert
May 17, 2011 | Plantronics CS55 Wireless Headset
My m2250 attendant comsole give me a display message -3 2794 and when i see this mesage and calls comes in i cannot hear the person on the other end
You may be in the headset mode or your handset may be plugged into the headset jack, depending on the model of your phone.
Aug 13, 2010 | Nortel MERIDIAN M2250 ATTENDANT CONSOLE...
Is it compatible with an IPCC nortel network phone?
I am personally using a Plantronics CS60 wireless headset with a Meridian Nortel M2006 Phone and it works just fine.
Here is how you can setup the Plantronics CS60 wireless headset.
NOTE: Before setting up the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
Jun 02, 2009 | Plantronics CS60 Wireless Headset
Quick Red Flashing Light on Lifter
I think I just fixed the same problem on mine...
My phone has a headset button. It took a couple tries - but 2nd attempt it worked & I see no more flashing red.
I pushed my speakerphone button on the phone, then hit the lifter button on my headset...then hit the sensor button...and voila!
Jan 13, 2009 | GN Netcom Remote Handset Lifter GN-1000RHL...
Meridian console m2250
THE HANDSET IS PLUGGED IN UPSIDE DOWN
Aug 14, 2008 | Nortel MERIDIAN M2250 ATTENDANT CONSOLE...
Plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
Aug 04, 2008 | Plantronics PL-CS55 Wireless Headset
Help
Remote ring detection provides a low tone * triple beep in your wireless headset when you receive an incoming call. This feature requires a handset lifter accessory, such as the Plantronics HL1 or HL10. If you do have a handset lifter but do not hear the remote ring detection, please check the following:
  • Check the placement of the lifter. - Make sure the handset lifter positioned directly over the phone's speaker.
  • Try adjusting the phone's ringer volume. If the phone's ringer is too quiet, it may not trigger the ring detection built into the lifter. Try turning up the ringer volume of your phone.
  • Check the ring tone of the phone. - If your phone's ring tone provides short beeps or plays music, the lifter's microphone may not detect it. Try switching your ring tone to a traditional ring or long beep.
  • Does the phone have different rings? - For example internal calls vs external calls vs transferred calls. Does the phone ring the same for each type of these calls. If so try changing so all calls use the same tone.
  • Attach the optional "external ring detector" cable. This cable plugs into the lifter and provides a small, black microphone. It is included in the plastic bag of lifter accessories. Mount the microphone near your telephone's speaker. Click here for more details.
  • There are 2 versions of the Lifter accessory - HL10 and HL1. The HL1 is a larger older version of the liter with a more sensitive rind detector. Some phones will require the older version of the lifter.
  • Please view the On Line Compatibility Guide to see if the older version (HL1) will be required for your phone.
*Please note the volume of notification beep in the headset cannot be altered, it will always be a low tone triple beep .
Jan 15, 2008 | Plantronics CS50 Wireless Office Headset...
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
