Question about Philips Magnavox 42MF521D/37 Television
Magnavox 42MF23ID/33ID 42 inch Plasma TV It popped and seemd to blow off. Unplugged it and replugged. Smells like something burnt. It clicks and the blue light on the unit (on/off switch) lights for a second and goes off. So I unplugged it.
SOURCE: Philips 42 in. Plasma shut down
Thank god we purchases the ADVANCED extended warrenty. This tv has been nothing but problems.
Fuzzy picture, picture shutting off after 20 sec coming back on and now blog of colors shut off never to come on again. 7 blinking red lights on the front. Waiting for the repair man again.......
Posted on Apr 13, 2008
  • 90 Answers
SOURCE: 42" magnavox plasma started to smoke, has audio but no video?
power board replacement a burnt circuit is visible upon opening unit and removing the power board.
Posted on Jan 29, 2009
  • 44 Answers
SOURCE: blinking red lights
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 02, 2009
dsacco86
  • 1077 Answers
SOURCE: Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Posted on Aug 12, 2009
roety
  • 585 Answers
SOURCE: 42 in magnavox plasma tv has sound with no picture
Hi my name is Roety,
I can help you with your issue ,
If you have no TV menu either check for any swollen capacitors on the power supply.
If none are found measuring voltages will localize the defective board or boards the voltage test points are marked VA and VS on the panel and boards.
If disconnecting boards restores these voltages the suspected boards must be replaced .
Tech labor is about $250 plus parts.
Suspected boards
power supply
Y sus main & Y buffers
Logic board
mainboard
panel
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Dec 30, 2009
I have a LG plasma 42PC1DG, watching tv loud pop then no picture but still have sound, left tv unplugged for a while still no picture?
probably the pop was a fuse blowing inside that only controls the lamp should be an easy fix but open the tv at your own risk
Dec 06, 2010 | LG 42PC1D 42 in. Plasma Television
Magnavox 42MF231D/37 screen went white then black
Alot of times i have noticed that when i have worked on these, it has been the Backlight Inverter. 32 inch televisions had same problem as the 42 inch
Oct 18, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Jan 27, 2009 | Televison & Video
No power to tv after unplugging and replugging
either the fuse is burnt out inside or the the problem is the power supply board. You can remove the back cover to see if the fuse is good or not.
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Magnavox 42MF230A/37 Plasma TV should i fix it? ?
you will need that part to repair yours. i recomend using the heatsinks from yours. u need to check the FETs on the board that drives that one before u power it up, or u could damage the new part.
Dec 05, 2008 | Philips Magnavox 42MF521D/37 Television
42" magnavox plasma tv
I partly agree with imaliszewski the problem is Y buffers (upper & lower). There is 3 parts to the Y board (Y-main, Y-upper, and Y-lower). There was an issue with defective Y-buffers in a memo sent out by the Plasma manufacture. The problem could be that you just got a set of these defective buffers in your panel. Or as Imaliszewski stated a current problem. but if you replace the Y-buffers repace them as a set. If your TV goes out again after changing the buffers. The panel is causing the problem by drawing too much current. That was a Defect I found out why working in a Philips/Magnavox warranty repair facility.
Jun 11, 2008 | Philips Magnavox 42MF521D/37 Television
I heard a loud pop sound and my 48 zenith plasma tv picture went black. Even the words "video 1" don't show up when selected. It's getting power; The green/red light is on. I've checked all the...
Does anything come on the screen? Input display box?
If no:
Sounds like it could be a blow capacitor. Cheap part, but need someone with a little electronic know how repair to fix it.
Mar 14, 2008 | Zenith P42W22B/H 42 in. Plasma Television
Receiver is powered, monitor is not
You probably have a broken TV if it's still under warranty you should call the manufacturer.
Jul 25, 2007 | Hitachi 42HDT52 42 in. Plasma HDTV
Philips Magnavox 42MF521D/37 Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
