When disc is loaded, starts transfer then stalls! Will not begin again have tried perhaps 25 times.
  • 3,530 Answers
Welcome to Fixya
Try to use a cd cleaner to clean the lens of the disc drive. If possible, could you provide more details of the problem. Are you referring to your computer? Are you trying to install windows?
You response will be highly appreciated.
Thank you for using Fixya!
Posted on Jan 04, 2011
CD Changer won't finish loading a CD
I had the same problem and found the cure for it. The drive belt was streched and when it started to close on the disc, the belt would slip and eventually show loading error..The two belts cost $4.50 at belts plus. Hope this helps you
Feb 21, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
Just recently bought a 2003 Mazda RX8. Everything fine until I came to set of traffic lights about 10 miles from home and the engine stalled and I could not re-start it. Got towed home and then tried the...
You say he removed the fuel pump fuse? Do you mean he changed the fuse? The fuel pump can't work without the fuse. Perhaps the fuse is blowing and causing the engine to stall and not restart. Find the fuel pump relay and swap it with another relay of the same type. Make sure the fuel pump fuse is good. If the engine starts, drive it around close to home until you think it's had time to stall out again. If it down'nt stall this time then the relay is bad and needs to be replaced.
Jan 05, 2011 | 2004 Mazda RX-8
Installation software for VGA PC Camera 25-157 won't run/finish
Download the microsoft clean up utility and look for any programs relating to webcams - logitech etc.
You may have old software in your registry creating a conflict.
http://support.microsoft.com/kb/290301
Apr 25, 2010 | Radio Shack VGA PC Camera Webcam
Stalling and bucking!
Injectors, even if one is bad, the increase in resistance in the SFI system kills the other injectors too. When it starts to run bad, unplug injectors one at a time to see if it runs better.
Feb 23, 2010 | 1990 Buick Century
Mantis 4 cycle (brand new): oil leaking out, smoking soaking air cleaner, quits running..
Sounds like your gas tank is not breathing properly. try this: the next time you run the tiller and it begins to stall out, try loosening the gas cap. It should start running again. This means that the gas cap is clogged. Unclog it or purchase another one.
Jim
May 30, 2009 | Mantis 4-Cycle Tiller
I have a compaq V2000, and it will not read the D:/. It just says blank disc when I put a disc in.
I imagine D:/ means DVD CD drive perhaps you to look and see if it has aded in the device manager if not load it again and even check the bios at the beginning.
Jul 14, 2008 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
