NEC MultiSpin ND-1100A (ND-1100A) DVD+RW Burner Logo
Posted on Jan 04, 2011
I need the driver of nec 1100a dvd rw - NEC MultiSpin ND-1100A (ND-1100A) DVD+RW Burner
2 Related Answers
Anonymous
  • 48 Answers
  • Posted on Jun 29, 2007
SOURCE: nec dvd + rw nd-1100a
first try a audio CD see if ti reads that fine. then inset a data CD and see if you can see all the files on it. Try a few data and audio CD's. If it has trouble with any of these your drive has gone to the great garbage dump in the sky.
Anonymous
  • 382 Answers
  • Posted on Oct 24, 2007
SOURCE: NEC DVD+RW ND-1100A
This is a single layer drive only. Usually dual layer drives have DL in the form factor so possibly a
NEC DVD+RW DL?
http://www.adamant.com/itemInfo.asp?GotoID=ITEM&PrdAbr=CDVN-3540A&menu=PARTS
Jumper setting in cpu
Not sure what the CPU has to do with anything! The following might help with CD/DVD drive jumper settings:
http://www.computershopper.com/storage/howto/installing-a-new-dvd-burner4
Will not read any dvd
make sure the CD or DVD media you isnert is compatible for read/write opeartions
this DVD/RW is 12x40 trasnfer (rate read) and 4x16 write +RW
what format or speed CD media are you inserting ? go to this link to give you a better look at the specs of this NEC product you have
http://support.necam.com/optical/specs/nd-1100a.pdf
if this helped you , please rate me
1helpful
My dvd rw can't read dvd cd but they can read a cd only
try to go to registry editor and delete upper/ Lower filter. It should resolve the issue
What is the jumper setting as slave?
All drives are different, you have to look on your drive for the pin config
XP can't find ND-1100A drive
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
NEC DVD+RW ND-1100A
NEC DVD+RW DL?
Nec dvd + rw nd-1100a
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
