Question about Samsung YP-U3 MP3 Player
My samsung yp-us mp3 player suddenly stops and do not power on. Even if i connect to a pc, i can view the drive as a usb but there were no reflection on its monitor unlike before. At times there are glimpes of blue light flashing on the monitor if ai move a bit the usb connection. Is there any problem with its internal connection? How to fix this? I then format the drive using a pc? How to retun back its firmware and how to resolve all this issues? Will this call for a replacement? Please help
Noggin
  • 944 Answers
SOURCE: connect to pc and repair firmware with recovery utility (SAMSUNG YH-820MC )
try formatting your player completely, then reinstall the firmware from scratch - another possibility is to remove windows media player (make sure you don't delete all your music files while doing this) and reinstall. If this doesn't help then it sounds as if the memory in the player could be faulty - check the warranty try a different cable and port to connect to in case that is the problem. There are numerous utilities that claim to repair windows registry errors, some of them may be worth a try - http://free.grisoft.com/doc/1 gives the links for the best that i have found for free. try updating the firmware from another pc - ask a friend if you can use their machine and uninstall everything after, especially if you think the problem is with your wmplayer. Hope this helps :)
Posted on Mar 11, 2007
kjanx
  • 194 Answers
SOURCE: Samsung MP3 Player YP-Z5F
is there a reset button [pinhole] on the player??
should fix it
Posted on Feb 02, 2008
SOURCE: Samsung YP - Z5F
Samsung YP-Z5F
Will not always switch on and when it does switch on will not respond to control panel
Posted on Apr 07, 2008
Posted on May 10, 2009
SOURCE: Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Posted on Jun 20, 2009
I want to remove existing music
You cannot delete existing mp3 files/directories directly from the player but it is possible from the computer. Connect your mp3 player to a PC using the USB cable. It should become visible as a mounted removable drive.
If you can't see it, go to settings -> system and switch the UMS mode at the bottom of the list so it can become visible.
You should be able to see the drive in windows explorer and on Windows, you may even be asked as the drive connects if you want to view files,
Simply go to the directory structure, click through to music and delete files/folders that you no longer want. You can copy over new files from wherever you store your music, too. It's the same connection/viewing process.
Jan 01, 2014 | Samsung YP-Z5 MP3 Player
How can I delete songs from my Samsung YP-U3 MP3 Player?
  • 1 Turn on your computer. Connect your Samsung MP2 Player to your PC via the USB cord. Power on your Samsung MP3 Player.
  • 2 Wait for the popup screen and select "Open Folder to View Files." If no screen appears, navigate to my computer and double-click the Samsung player.
  • 3 Select the MP3 files you no longer want on your player by highlighting them with the mouse.
  • 4 Right-click and select "Delete."
  • 5 Close the folder and safely remove the MP3 player by using the "Safely Remove Hardware" feature in the system tray.
  • Mar 02, 2011 | Samsung YP-U3 MP3 Player
    How do i delete songs from my samsung yp-u3 mp3 player
    Greetings, Step 1 Turn on your computer. Connect your Samsung MP3 player to your PC via the USB cord. Power on your Samsung MP3 Player.
    Step 2
  • Wait for the popup screen and select "Open Folder to View Files." If no screen appears, navigate to my computer and double-click the Samsung player.
  • Step 3 Select the MP3 files you no longer want on your player by highlighting them with the mouse.
  • Step 4 Right-click and select "Delete."
  • Step 5 Close the folder and safely remove the MP3 player by using the "Safely Remove Hardware" feature in the system tray.
  • Sep 26, 2009 | Samsung YP-U3 MP3 Player
    How do I charge Samsung MP3 player Yp-U3 Samsung YP-U3 MP3 USB port not connected to the computer
    The player needs to be charged via the USB connnection on your PC. If it doesnt fit, try the USB ports on the back. If its not working/not charging, please test the MP3 player on another PC.
    Jan 21, 2009 | Samsung YP-U3 MP3 Player
    Samsung YP-T7J MP3 suddenly doesn't work with USB on PC
    hi
    i have a samsung yp-t7j but i don`t know how to turn on .please help me
    thank you
    Nov 19, 2008 | Samsung Yepp YP-T7JX MP3 Player
    Oct 11, 2008 | Samsung YP-Z5 MP3 Player
    Not displaying all files while connected as a USb
    Your MP3 player is virused. clean virus then and in your pc done : tools-Folder option -view-(mark)show hidden files.. and (unmark) hide extension ... , hide protected... so change hidden folders in your MP3 player
    Dec 17, 2007 | Samsung YP-U2X Digital Media Player
    Samsung YP-U3 MP3 Player Logo
    51 people viewed this question
    Top Samsung Audio Players & Recorders Experts
    Electro Med Services...
    Electric Dime
    Electric Dime
    Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
