I purchased an rca rlc1906 19" tv 2 months ago, worked fine when i turned it off last night, when i got home from work tonight i tried turning it on. but all i had was good volume but had no picture, just a blank white screen. how can i correct this? the manufacturing date is aug 2010 however i have misplaced my receipt. please help.
  • 3 Answers
Same RCA RLC1906 LCD T.V.
"Same problem"; working normal shutoff, and never came on again; just white screen.Took off back cover to inspect "CAPS"... all looks good.
To this point only thing that seems odd is resistance varies 50ohms between diods D5, D6, D7 on main power supply. On another note
our tv was supposedly a refurb yet considering that fact; I closely inspected all three circuit boards, and none show any signs of repair, meaning everything appears new, original. If the capacitors are blown it should be pretty obvious by swelling or leakage. I don't see any of those obvious signs of heat damage. Diode's don't appear shorted when reversing polarity but D6 specifcally tests just over 600 ohms, all others test just over 550 ohms though I believe they are all suppose to be identical value. Perhaps that helps but I am going to try replacing diodes first and retry as it does seems power supply is also connected to video input/output which I would think is inverter board!
Posted on Feb 04, 2013
SOURCE: No Picture on Viewsonic TV
That is a coincidence. My tv went out the same night. But mine wont even turn on at all. So far I have had no luck finding anyone to repair it. Let me know if you figure something out and I will do the same.
Posted on Jan 16, 2008
  • 8 Answers
SOURCE: LCD TV White Screen
do you still have this tv? what happens if you hit the info button - does it bring up the banner at the bottom of the screen?
Posted on Feb 12, 2008
  • 718 Answers
SOURCE: have a 42 in rca lcd tv ,hsound but no picture
IF the set is under warranty, you should return it.
Do this to see if your set is "sending" the image to the LCD panel.
1) What the set on take a bright flashlight and press it against the screen.
2) Look for the "image" moving around the edge of the flashlight.
3) If you see the "image" then the problem is in the inverter/CCLT or the power to it.
4) If you do not see the "image", you should look at the LCD controller(TCON) for the problem.
Posted on Feb 25, 2009
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
ginko
  • 19396 Answers
SOURCE: Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
Posted on May 30, 2009
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
My TV was working fine when I turned it off last night. When I turned it on tonight the picture both on TV channels and when I played a DVD was hidden behind a kind of patterned grey curtain. Sometimes I...
This problems is the board call the T-CON decoder board is the causes and the problems.This board is dying.The T-CON decoder board sit in the middle at the bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoder board for the replacement.
Jan 13, 2011 | Sharp LC-32D47UA 32 in. LCD HDTV
We have a 52 inch RCA projection HDTV and today it just stopped working. It doesn't turn on at all. There is no power light or sounds or anything coming out of it. It was fine the night before and when I...
I had the same problem which got fixed today. It was a loose connection to the power supply unit that required some soldering by a technician and cost me 56$. My TV works after 2 months.
Aug 28, 2010 | RCA D52W23 52" HDTV CRT TV
TV flips through channels at 2 channels per second.
It sounds like a button is stuck or bad. I would spray some electrical cleaner on the buttons 1st. If that don't work, the switch is probably bad.
Jul 23, 2010 | RCA F32645 32" TV
I purchased my tv 2 years ago. Watched it
Try leaving the TV unplugged for 30 minutes so theTV can reset itself.
If that doesn't work, most likely the TV has a power supply board is the problem. Or, it's just a fuse that blown inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Garmin NUVI 200w
the same issue with mine, but mine cut out after one day. Purchased 6-9-08
Jun 09, 2008 | Garmin nuvi 200W GPS Receiver
Will not turn on
  • I just finished repairing the same model TV for a friend who had the same problem. My trouble shooting led me to cold solder connections on the flyback transformer. After repairing the connections the TV works just fine.
  • WARNING: IF YOU ARE NOT EXPERIENCED WORKING ON A TV, TAKE IT TO SOMEONE WHO IS. THERE ARE DANGEROUS HIGH VOLTAGES WHEN THE SET IS OPENED UP.
  • HamOperator
Apr 09, 2008 | RCA 20F420T 20" TV
Need help fixing
I had the same problem a couple years ago with mine. After letting it set for several months, I tried to plug it in again after moving into another house. All of a sudden, it started working again. That was 1 year ago, but just last week...it did it again. I noticed that it does this if it is left on for an extended amount of time (my wife goes to bed at night and leaves it on). I cannot find anything on how to fix it, and no warranty assistance from RCA. I'm purchasing a Sony today, but will hold onto the RCA in case it decides to work again.
Sep 29, 2006 | RCA RT2380 System
Televison & Video Logo
499 people viewed this question
Top Televison & Video Experts
