Question about SYMA Toys industrial New Syma S107 Mini Indoor Gyro
I can not get more then a foot off the ground
  • George Hels
    George Hels Jan 04, 2011
    Is it getting a full charge? How long is it taking to charge, and are you charging it with the USB cable into your computer or using the remote charging cord?
    Problem Solver:
  • 15 Answers
It is makaniks problem,pelace go ther
Posted on Jan 04, 2011
How do I design a 6 foot diameter circle for my garden?
drive a peg in the ground where you want the center of the circle to be
get a piece of string and make a loop at one enf big enough to fall over the peg
measure out 3 ft from that loop and tie a stake at that point
now pull the string until it is tight and where the peg hits the ground make a mark
move about a foot an make another mark keeping the string tight all the whole
repeat the process until you have done a complete circle
the marks will be the circumference of a 6 foot diameter circle
Oct 12, 2014 | Esschert Design USA Esschert Design...
Tip
How to set ark welders with more than fifty foot of welding cable
This tip is referring to welding machines using fifty foot add on sections of welding leads.
Number one: Set the machine with just the stinger whip(six to eight foot long) and a fifty foot ground lead.The ground lead can be shorter.
Number two: Get a piece of scrap plate the same thickness as you will be welding.
Number three: Set the plate in the position you will be welding in and clamp the on ground to to plate.
Number four: Turn on machine and set amperage dial to the size of rod.(if your using 1/8 rod set for 125 which is the decimal equivalent of 1/8) using decimal equivalents will get you in the ball park but depending on the coating , thick or thin you will have to adjust from there.
This will work for rods like stainless that have high resistance to current.
Number five: Once you have the setting that you like add five amps for every fifty foot of lead your using.This works for copper leads that are half inch thick and that all connections are tight. One more thing,if the rod is eating a crater ahead of the arc your running to hot.
on Jun 10, 2011 | Welding Tools
What is the standard size of a billiard table?
There are three standard sizes for billiard tables - 7-foot (3.5' X 7'), 8-foot (4' X 8') and 9-foot (4.5' X 9'). The standard height of a table is between 75-80cm when measured from the playing surface to the ground.
Jul 25, 2012 | Sport & Outdoor - Others
No second gear
Instructions
1.
The 2nd gear lockout is, a mechanical speed sensing mechanism. It doesn't care if the engine is running. You bypass it by scooting the bike forward, about 5-6 mph, while shifting the transmission into 2nd gear.
Stand on the left side of the bike, with the ignition "ON" and the transmission in neutral.
3 With your right foot on the ground, behind your left foot: place your left foot on the left foot peg, with your toe under the shifter; squeeze in the clutch.
*4.Scoot the bike forward about 5-6 mph, with your right foot, and shift the transmission into 2nd gear, with your left foot. If you accidentally go into 3rd, or some higher gear, you can easily shift back down into 2nd, without further movement of the bike.
5.To start the bike: Apply the choke if the engine is cold. Squeeze in the clutch and push the bike forward, both feet on the ground, about 8-12 mph. Release the clutch until the engine start
6
As soon as the engine starts: squeeze in the clutch and shift the bike into neutral.
Apr 23, 2011 | Suzuki GSX 750 EF Motorcycles
Change new battery now car runs really bad do I need to reset the computer?
disconect the ground wire from battery then turn key just like you are trying to start it with your foot on the brake hold for 60 sec. then turn key off and remove foot aff brake and reconect ground wire to battery and then start it should reset the computer.
Mar 04, 2010 | 1992 Honda Civic
The foot step ground skirt around the truck, the
Lower front valence, but Ford may call something else.
Feb 14, 2010 | 1995 Dodge Dakota
Bypass iXA-W404
The 404 requires multiple signals from two separate wires to turn off the video block. Simply grounding one wire will not work. There are bypass modules that will send these signals to the head unit available on ebay. Just search alpine 404 bypass. Your other option is to use two toggle switches to simulate the parking brake and foot brake signals necessary to disable the video block.
Jul 08, 2009 | Car Audio & Video
Attaching (VV-283F) Vivitar 283 foot
Use Red wire to Center.Use Black wire to Ground.Other two, just insulated them.a.l9609@gmail.com
Feb 28, 2009 | Vivitar 283 Flash
Raplacing 3 wire cooktop with 4 wire cooktop
if you look in most panels the ground and the neutrals are tied to the same ground. they might be in a different location within the panel but they are common to each other. if you are concerned about having a seperate ground get yourself a ten foot, one inch diameter copper rod drive it into the ground about nine foot six inches. then mix up a strong salt water solution, about a couple of gallons and pour it around the rod. voilla, you have an independent ground. this might sound like a bunch of bull ----, but it is valid information. if you still have reservations call the building department in your town and they will verify it for you.
Jan 06, 2009 | Jenn-Air JED8230 Electric Cooktop
SYMA Toys industrial New Syma S107 Mini Indoor Gyro Logo
188 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
