Question about HP LaserJet M3027x MFP Printer
I tried to reset PIN of HP Laserjet M3027 MFP. But I am not getting option
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
SOURCE: touch screen on hp laserjet m 3027 mfp not working
turn of the printer. Hold the C and # buttons and turn on the printer. When the screen goes black it will be ready to be re calibrated. there is a white dot, touch it with a pen, another white dot appears, touch it with a pen. It will continue to turn on now with a newly calibrated screen.
Posted on Nov 25, 2009
  • 313 Answers
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Posted on May 07, 2010
seeker5211
  • 1089 Answers
SOURCE: HP Laserjet M2727nf Mfp.
Turn off printer. Hold the CANCEL and > buttons, and turn on printer. When you see Permanent Storage Init release the two buttons. When the process completes you will see the ready message. This will reset ALL menu settings. If you screwed up the firmware update, you will have to replace the formatter. The NVRAM reset won't help you!!!
Posted on May 17, 2010
  • 31 Answers
SOURCE: logic card reset for hp color laserjet 1312 nfi
1. Turn off the product.
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
Posted on Aug 10, 2010
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
An email address must be provided for email notifications
I accessed the printer thru the web interface>Log In>>Digital Sending>Send to Folder Settings and under the Notifications I changed it to Print . It was set to Email Sender. We don't email from scanners not sure where that setting is located.
HP LaserJet M3035 MFP Series
Method used to deliver notification: Print
Jan 28, 2014 | HP LaserJet M3027 MFP Printer
Hard reset
Go here: http://www.hp.com/sbso/product/mfp/demo/m3035-3027.html
Watch the simulation and follow the instructions.
Mar 13, 2013 | HP LaserJet M3027 MFP Printer
Cold reset hp laserjet M3027/3035
Power on printer 1. as soon as memory check starts press and hold the 6 key down. When all the LEDS are ON release 2. use the 3 and 9 keys to scroll through the options. 3. press 6 to select the option
Sep 02, 2011 | HP LaserJet M3027 Printer
My hp 3027 printer cannot boot
Turn off and hold down the 6 key, turn on while still holding 6 until all 3 lights on control panel stay lit. Use the 3 key to scroll on screen until COLD RESET is displayed, then touch 6 again and should reboot. If you are not getting a display at all you need to get a FORMATTER
May 07, 2010 | HP LaserJet M3027 MFP Printer
HP LaserJet M3027 indicates paper jam but there isn't a jam.
if you are getting a paper jam message but you can not find paper any where in the printer the first thing that you want to do is clean the pickup roller in the paper tray. the roller is located on the top of the cavity that the paper tray is installed in.
Mar 11, 2009 | HP LaserJet M3027 MFP All-In-One Printer
I have a m3027 mfp hp printer top feed won't grab
turn the power off.remove ink cartridge then check there is not any paper jam.aslo check in back side of printer for paper jam .also clean your ink cartridge try other ink cartridge.
Jan 05, 2009 | HP LaserJet M3027 MFP Printer
Touch screen on hp laserjet m 3027 mfp not working
Dec 26, 2008 | HP LaserJet M3027 MFP Printer
HP LaserJet M3027x MFP Printer Logo
541 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
