Question about MSI (MBOXKM4MV) Barebone
Msi p4m890 900m2 In that mainboard, I want to know, what is max: DDR2 Gb?
    Novelist:
  • 127 Answers
The maximum amount of RAM that that motherboard can hold is 4GB. You should also know that 32-bit WIndows Operating Systems will only use 3GB of RAM though. 64-bit Operating Systems will recognize and utilize more.
Posted on Jan 04, 2011
What is the max memory for MSI G71-mv31013-J24motherboard
Hello enter the msi mainboard number here:
http://www.msi.com/service/download/
The number is printed in on the mainboard:
This is just an example.
Good luck
Mar 06, 2013 | MSI Computers & Internet
"M2V-MX SE"MOTHERBOARD WHICH MEMORY USE
Hello here are the info about the mainboard:
http://www.asus.com/Motherboard/M2VMX_SE/#specifications
The mainboard uses:
2 x DIMM, Max. 4 GB, DDR2 ram.
The driver download site:
http://support.asus.com/Download.aspx?SLanguage=en&m=M2V-MX%20SE&p=1&s=24
Good luck
Feb 26, 2013 | ASUS M2V-MX Motherboard
Memory Type:DDR2 SDRAMNumber of Memory Slots:2 x 240 Pin DIMMsSupported RAM speeds:333 MHzMax Supported RAM:4 GB
Mar 19, 2012 | MSI 7529-050R Motherboard
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
I have a ms 7312 what is the max memory I can install on it
Hello, I've pasted the below from the MSI website for the board:
bult_ar_org.gifMain Memory
• Supports Dual DDR2 533/667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 2GB.
regards,
Nicam49
p.s. don't forget XP supports 2gb max anyway.
Oct 16, 2010 | MSI K9MM-V Motherboard
What is the ram supported for hp motherboard RC410-M
This Motherboard DDR2 SDRAM RAM and with a max RAM support up to 2GB.
Jun 03, 2010 | MSI RC410M-L Motherboard
MINHA PLACA-MÃE (MSI PM8M3-VH)É DDR OU
English is understood here.
Read your user manual or search for a download on the Internet.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=234
"Main Memory
• Supports two memory banks using two 184-pin DDR DIMM.
• Supports up to 2GB PC3200 (DDR400) SDRAMs.
• Supports 2.5v DDR SDRAM.
(For the updated supporting memory modules, please visit
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_trp_list.php )"
Oct 23, 2009 | NEC I/O Plate for Motherboard
Pc5300 on pc3200 slot to upgrade msi 845gvm-v
PC5300 or more correctly "PC2-5300" and can work in a system that has "PC2-3200" RAM, and if mixed, they will operate at the speed of the slowest module. "PC-3200" RAM, however, is not compatible. PC-3200 is DDR SDRAM, having 184 pins. PC2-3200, and PC2-5300 are DDR2 SDRAM, having 240 pins. DDR and DDR2 modules are the same length,
but the pins on DDR2 are smaller and the keying notch is in a slightly different position.
You need to get the replacement ram all the same type ie - DDR or DDR2
And yes your motherboard should accept 2GB max
Jun 15, 2009 | MSI 845GVM-V (MS-7057-010) Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
MSI (MBOXKM4MV) Barebone Logo
639 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
