Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
My Baracuda mostly does not start when the timer goes on. I have to move it around and play with it - before it starts. Then after a while, it again stops - then i have to repeat the fiddling process before it starts again. PLEASE HELP
  • 100 Answers
Clean the small wire filter that is inside the line where the line actually plugs into the side of the swimming pool
Posted on Jan 04, 2011
Unbalanced load at nearly every spins cycle ,move clothes around until it spins
Is it a front load or top load? Do you have the make and model?
Jan 26, 2015 | Washing Machines
The device goes for about three minutes, pulsating and moving around then it stops. Air appears to be getting into the system. I have checked the hose line and it seems airtight. I taped up the visible...
The plastic hose only last about two years. I think the chemicals eat away at the plastic. They will get a hair line crack down in the valley of the hose and **** air. Replace the hose.
Feb 27, 2011 | Zodiac Baracuda Zippy Pool Cleaner
Barracuda has plenty of suction but hardly moves around the pool, goes very slowly
You likely just need a new pad on the head. When they ware down they allow the head to get closer to the surface that it's cleaning, but the additional suction makes it difficult for the head to move.
I hope this helps you!
Jan 29, 2011 | Zodiac Baracuda Zippy Pool Cleaner
MY POOL CLEANER WILL RUN FOR A FEW MINUTES, THEN STOP. SO METIMES IF I SHAKE THE HOSE IT WILL START AGAIN. ANY ANSWERS?
Hi , most pool cleaners run by the force of the sucked up water moving gears inside the cleaner .. if yours is this way, then any blockage in the cleaner or in the hose attached would restrict the flow and keep the cleaner from moving.
Apr 30, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Matsui mwm145w goes straight into a spin cycle
Try to move the timer to a different postion if it still does the same thing turn the timer one full turn and try turning it on again if it still does it you have a bad timer, as for the bounceing that could be casue the leg stops need to be adjusted so machine is level, You may have a bad drum roller as well.
Aug 20, 2009 | Washing Machines
Washer will not go onto next cycle
Timer control is bad needs replaced
85 -100 dollars
Jun 02, 2009 | Washing Machines
Baracuda G4 won't clean whole pool. goes to a corner and stays
Maybe your hose needs to be reprogrammed by unhooking and lying it in the sun for several hours.
Apr 25, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Whirlpool Ultimate Care II Quiet Dry I, LEQ9508PWO
I would suspect the timer is on it's way out the door. Do you have any areas the timer has dead spots? Check the exhaust for any plugging also.Is this only on a first time start up or is it after this dryer has been running? If after running it could be a high temp sensor, that by the time you are playing around with it, the temp has changed.
Jan 24, 2009 | Whirlpool LEQ9858P Electric Dryer
Kenmore Dryer
yes it does sound like the timer itself. sometimes if the timer has a bad contact then the timer will loose power as it goes around. by turning the timer around 1 time it resets the contact and it starts up again.
Jun 28, 2008 | Dryers
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
144 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
