Question about Buffalo Technology AirStation G54 WHR-HP-G54 Wireless Router (DHWHRHPG54)
Trying to get connection settings on DSI for Buffalo WHR-HP-G54. It is asking: SSID- WEP Key- Auto-obtain IP Adress No or Yes How do I figure out what settings to use?
davecon
  • 85 Answers
SOURCE: cant get on buffalo main page
jasedrisk
consult the manual that came with the equipment
every manufacturer have their own default ip address use in loggin into the router main page
Posted on Apr 19, 2008
SOURCE: Problem with my buffalo airstation G54 WHR-HP-G54
Did you set your wired network connection to 192.168.11.x with a subnet of 255.255.255.0
That should make you be able to connect to the router directly if the router has the default settings on it.
Posted on Jul 29, 2008
  • 53 Answers
SOURCE: NINTENDO WII CANT FIND ACCESS POINT (BUFFALO WBMR-G54)
defenately call nintendo, i hooked up ours and i think the access point or brand is not compatable with the wii, something with the mgz, they will let you know.....wii has problems with an estimate of 6 or 7 diffrent models.....and make sure it's on the wek setting tho it's a bit picky, then again with all it does on line it's just trying to protect you.....shia
Posted on May 03, 2009
  • 121 Answers
SOURCE: Can you portforward to host online games'? Using BUFFALO WHR-G54s
Although the specific ports may be different depending on your console )or PC) and game, the following example shows step-by-step how to enabl eport forwarding to open your NAT for game hosting, etc.
http://portforward.com/english/routers/port_forwarding/Buffalo/WHR-G54S/Echolink.htm
Posted on Feb 20, 2010
  • 17 Answers
SOURCE: I dont remeber the password
You can reset your Buffalo router by pressing and holding the reset button on the back of it for 4-10 seconds. The IP address to sign into the router will be 192.168.11.1. The username will be root and the password should be left blank. The following website has more information on your router also.
Posted on Sep 16, 2010
I have this router but i want to know hoe to secure my internet connection
By default, the firewall on it should block all incoming connections from the WAN or internet network port (good thing). Make sure you do two things : 1. Change the default password on the router, and 2. secure your wireless using WPA2 for authentication and AES or TKIP for encryption. Also, rename your SSID to something that doesn't give away that fact that your router is a buffalo. I'm paranoid, so I donot broadcast my SSID...if you are too, then this is a good option.
Oct 22, 2013 | Buffalo Technology AirStation G54...
Unable to locate WEP key. Adding device to wireless network. Using WHR HP G54 model
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Aug 19, 2011 | Buffalo Technology WHR-G54S Wireless...
Trying to hook up DSI to AT&T 2701HG-B gateway to make it wireless
hi,
So you want to connect your Nintendo DSI to your 2wire modem.
Here are the steps for connecting you DSI wirelessly:
1. First you need to realize that the game console the requirements for the wireless password should be WEP.
2. Open the Nintendo DS setup Utility
3. Select the Nintendo Wi-Fi Connection Settings
4. on the next page just click on the search for an access point.
5. then click on your wireless name.
(when you still using the default name for your 2wire it will be 2wirexxx "XXX last 3 numbers of the serial number of the 2wire modem")
6. when it is asking for the wep key it is the 10 numbers under the barcode of your 2wire modem.
7. Select No under Auto-obtain IP Adress.
8. click Save settings.
this is the steps on connecting your DSI for wireless connection.
If this doesnt work call At&t for connecting your DSI.
Thank you for choosing FIXYA.
Mar 04, 2011 | 2wire 2700HG-B Router (2700HGB)
I have lost my network key password. Do I have to reset the whole system again ? Can I locate it on my computer ?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 10, 2011 | Buffalo Technology AirStation G54...
Need wep/security key
log in to the router by typing http://192.168.11.1 into your browser, the default user name is root leave the password blank. The wireless encryption page is available from Home by selecting Wireless Encryption. Here, you can manually select the type of wireless encryption you'd like to use.
Jan 05, 2011 | Buffalo Technology AirStation G54...
I need to connect to one PC trougth my buffalo router, I have the Public IP, but I don{t konw hoe to configure the router and the pc
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Apr 28, 2010 | Buffalo Technology AirStation G54...
Cannotuse my desktop and laptop simultaneously with wcr-g54, if the other connects the other hang or have limited or no connection
Are you using router/ Then you are using same IP adress at the same time try to change the last number on one of the unit if one is 192.168.1.5 then the other should use 192.168.1.10. Its on the LAN setting if you using static IP.
Oct 09, 2009 | Buffalo Technology WHR-G54S Wireless...
Can't get it configured
Try to reset the router using a paper clip, then try to re-log in to the router with the IP address, If you are still unable to log in , try log as admin as the username and password as admin or admin on the username and password is password.
May 26, 2009 | Buffalo Technology AirStation G54...
Trying to connect buffalo router to comcast modem for wireless internet
You will need to use the MAC address of your PC. Do an IPConfig/all while connected with a ethernet cable. That's whatg you need to put in under Wan--> WAN MAC address
Jan 17, 2009 | Buffalo Technology AirStation G54...
Buffalo Technology AirStation G54 WHR-HP-G54 Wireless Router (DHWHRHPG54) Logo
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Ali Reza
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
