Question about Philips GoGear HDD060 MP3 Player
La pantalla de mi MP3 esta congelada
Tengo un MP3 gogear 1630/17, estaba borrando un archivo de mi gogear a travez del explorador. En ese momento se cortó la energía electrica. Ahora no puedo apargalo ni hacer nada con el. La pantalla esta congelada con el logotipo de gogear. Ya lo he resetado con el boton de apagar y el volumen + pero continua igual.
No puedo formateralo porque mi computadora no lo reconoce como un disco duro.
Gracias
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: no funciona mi mp3 Philips GoGear SA178
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
  • 729 Answers
SOURCE: no enciende solo para traspasar informacion
Hola, este es traducida por Google Translate cliente.
Si actualiza el reproductor de medios digitales y sólo alcanzó el 60% en la actualización, el software (programa) piezas II y tiene que actualizar de nuevo.
Si no, puede tratar de explicar en otras palabras, de nuevo aquí.
Buena dias
lfete da DK
Posted on Mar 17, 2010
DRIVER POLAROID PDR 300
Hola a todos, el grabador tiene los controles en dos circulos debajo de la pantalla, en el de la izquierda, con el grabador ENCENDIDO, debes oprimir unos segundos el boton rojo del centro que dice ERASE, y aparecera la leyenda DELETE ALL titilando 3 veces, y luego dice FORMAT, tambien titilando. En este momento oprimimos nuevamente el boton ERASE y el grabador comienza a formatearse, en la pantalla aparece el mensaje WAIT, por lo que esperamos a que termine el proceso, y LISTO!!!, cuando lo vuelvas a conectar a la PC te reconocera las 4 carpetas. Tambien yo lo formatee con la PC y estuve varios dias con este problema. Pasa que luego de un tiempo de uso, y aunque vayas borrando las grabaciones que hagas, la memoria se ocupa totalmente y te pide el formateo. Espero que te haya servido. Saludos desde Buenos Aires
Sep 20, 2012 | Polaroid PDR302 Digital Voice Recorder
Saludos, mi endeavor tiene Una vibracion fuerte cuando va de 20 a 40 millas.
saludos, tengo una mitsubishi endeavor 2005, la cual me estaba dando exactamente ese problema, cuando iba acelerando entre 20 y 40 da una vibracion muy fuerte, el problema esta en la transmision, eso lo causa la falta de liquido de transmision, cuando a la transmision le falta liquido hace ese fallo para indicarte que le falta y que debes completarlo, mi recomendacion es que lo revises lo antes posible y que le heches un aditivo para transmision, hice eso y se le quito inmediatamenteee, cuando la revise estaba seca no tenia casi nada de liquido de transmision.
Feb 04, 2012 | 2005 Mitsubishi Endeavor
Como Reparo un Plasma Panasonic Viera TH-42PD60X no enciende ni el led de Standby
AMIGO YO TE VENDO LA TARJETA DE PODER PARA QUE NO SUFRAS MAS CON ESE APARATO , O TE COMPRO LA PANTALLA PARA EL MIO QUE ESTA QUEBRADA ,
Compro pantalla para PLASMA PANASONIC TH-42PD60X la mia esta rota, o vendo mi plasma para repuestos , tambien vendo una base para este plasma ya que tengo 2 unidades . gracias interesados escribirme a jaimolb@hotmail.com informes tel 0057 3207250204 colombia
Jan 21, 2012 | Cars & Trucks
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
QUIERO PONERLE CLAVE A MI WIRELESS INTERNET PK ME LO ROBAN Y MI COMPUTADORA SE HACE LENTA
Hola, debes entrar a la configuracion de tu router inalambrico, esto normalmente se hace mediante una conexion por cable a uno de los puertos LAN disponibles, buscas la opcion Wireless y activas en el campo Security mode, por ejemplo WEP o WPA, esta depende de cual o cuales soporte tu router, la recomendable es la segunda, luego estableces la contrasenia del WiFi en el campo PSK, guardas los cambios y posiblemente el router se reinicie, si no lo hace es recomendable que lo reinicies manualmente para desconectar a cualquier usuario no deseado que haya en ese momento. Estas son instrucciones genericas, depende del fabricante y modelo de tu router para tener mas detalles, la mayoria de routers traen un disco con el asistente de configuracion (Setup Wizard) que podria facilitarte esta tarea.
Mar 03, 2011 | HP Computers & Internet
La computadora dejo de trabajar al no llegarle enregia electrica
Estimado amigo Jose Diaz.
En la oportunidad que mi lap top no encendia, utilice el poder del AC y la falla continua.
Es de hacerte conocer que tengo conectado la computadora a un dispositivo de regulacion de voltaje para prevenir un salto de corriente que pudiera dañarla. El regulador de voltaje esta funcionando un 100%, y solo lo utilizo para conectar la Lap Top.
Espero me puedas responder pronto.
Tu amigo.
Eleazar Curiel
Oct 23, 2008 | HP Compaq Presario V2000 Notebook
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
Stereo
esta inabilitado porque cambie la beteria yen momento no tenia el codigo y aparedia en pantalla la palabea safe ,despues lo lleve al conseccionario para que me dieran el codigo el cual me dieron pero como todo aqui en este pais es un caos no pedieron por los momentos desabilitarlo ya que supuetamente tenian mucho trabajo en otras areas mas importantes que ocuparce del estereo en ese momento asi que tengo que pedir cita otra vez para cuando les venga en gana ,asi estamos en este pais sorri lo sieeto de veras tener que plantearlo de esta manera pero tengo que ver si lo puedo hacer yo mismo gracias de antemano.
Jul 21, 2008 | 2005 Volkswagen Jetta
No se ve el video en mi TV
yo tambien quisiera los codigos me harian un mega favor, les dejo mi correo manuelgutierreznevarez@hotmail.com de ante mano gracias
Nov 24, 2006 | Yahoo YHT-650 System
Philips GoGear HDD060 MP3 Player Logo
42 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
