Question about Sport & Outdoor - Others
I ran it out of fuel because of guage --- filled tank to the absolute brim, only fires if you give fuel in cylinder --- fully charged battery --- can hear pump when pull rope -- will not start -- ran absolutly flawless before???? this is an 05 mxz x 600 ski-doo
  • 784 Answers
From time to time water contamination is in the tank and when you run the machine out of fuel the pump picks that water up and now it is sitting in the bottom of the carbs. drain the carburetor bowls and disconnect the fuel line from the carbs and run fuel out for a few squirts,, re attach the hoses and then try and start it. ( 9 times out of 10 this will fix the problem ). also -- check and clean the plugs as they might be wet and fouled from the water.
c...
Posted on Jan 04, 2011
Batteries ran completely down now fully charged scooter wont work.
hi if youre batteries have been sitting for 18 months without a charge they r probably no good now after batteries sit for a long time the plates develop a coating & when u do charge them the they will not charge properly..youre charger guage is not a true reading the only way Is to use a battery LOAD tester this will give u a true reading on the condition of youre batteries...u can buy a battery load tester of e/bay for aprox $35 ........
Sep 06, 2015 | Golden Technologies Companion II Travel...
Know 2001Saturn ran out of has, was getting fuel,but it started with starter spray but won't stay running,battery is almost fully dead ,could that be why I am now not getting any fuel
no as long as its running the alternator will suply electric with it running out of fuel the pump and filter would have pulled all the muck from inside the tank put plenty of fuel in maybe quarter of a tanks charge battery after a few days it should be ok but if not get fuel filter changed hope this helps ivan
Sep 26, 2012 | 2001 Saturn L-Series
John Deere Diesel X495 garden tractor running VERY rough.
Bleed the lines while the unit is running making sure you get all the air out of the lines.
May 06, 2012 | Diesel Garden
91 S-10 won't crank over. Has battery power. Ran
After it fired right up, it stopped working? Check your fuel pressure as your fuel pump may have quit working.
Jul 10, 2010 | 1991 Chevrolet S-10 Blazer
2005 Nissan Pathfinder Gas guage malfunction
If you don't get offered a fix, this is a problem you can learn to live with.
Get used to filling the tank to the brim (that may not be so unusual in your part of the world - certainly is here, the way they tax fuel!) and resetting the trip counter on your dash every time you fill up.
For the first few times, fill up after a couple of hundred miles; note the amount of fuel it takes and the distance you've driven. Divide miles by gallons to get your average fuel consumption (average this over a few goes to get a reliable figure).
Find out from the user manual how much fuel the tank holds (if it gives several figures, the one you want is "useable" fuel). Multiply this capacity by the consumption you calculated earlier, and you'll get a very good estimate of the distance you can go before you run out.
Now all you need to do is to keep an eye on the trip counter, and remember to refuel every time you get to (say) 75% of your theoretical maximum distance.
This method has worked well for me over a number of vehicles, none with a particularly effective fuel gauge.
A.
May 26, 2009 | 2005 Nissan Pathfinder
06 kawasaki jet ski wont start
Oh. One more thing..... before spending money on repairs just try changing the plugs.
Aug 28, 2008 | Sport & Outdoor - Others
Fuel consuption
hi get the engines codes read see what is stored as if there is a fuel problem it will be stored have you sreviced it and i must addmit if i was to guess i would suspect the tps at fault or the cars miss firing yates210456
Aug 23, 2008 | 1998 Honda Passport
Sport & Outdoor - Others Logo
161 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
