Question about Intel DG31PR Motherboard
Upgrade bios i have a intel dg31pr motherboard computer when i want to install win vista it dose not accept giving a message that the bios is not acpi compatible. how do i upgrade the bios and where do i find free upgrades
Install upgrade bios from intel tools and support
Posted on Jul 28, 2008
I have loaded USB 2.0 Driver but System could not detect that USB 2.0 Port when I connect USB 2.0 device to all six USB Port. I am having DG31PR Motherboard. I checked in BIOS setup. High speed port enable...
You have not mention what Operating system is on your PC.
For Windows OS XP, you just have to install at least XP Service Pack 2 or higher... and the USB 2.0 ports will function. For Vista & Win 7 OS, the USB 2.0 drivers is in the Operating System when you install Windows.
Hope it helps.
Jul 13, 2011 | Intel DG31PR Motherboard
Pci driver is not installing
Intel DG31PR Motherboard has Intel 3 Series Chipset and you have to install the chipset drivers, which would install the PCI Drivers as well. Please visit the link given below, download the chipset drivers and install them.
Intel DG31PR Chipset Drivers
The above drivers support Windows 7, Windows 2000, Windows XP Home Edition, Windows XP Media Center Edition, Windows XP Professional x64 Edition and Windows XP Professional
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Intel DG31PR Motherboard
I just want to download Intel desktop board DG31PR software, to install it in my computer
Hello, Go to there website anddownload with the following steep. Just . CLICKHERE Type model no on the searchoption Choice the product (e.g.chipsets)> Desktop chipsets/laptop board> Choice chip no(e.g.865/945)> Selects your OS from leftside (e.g. sp/vista/win 7)> Click on driver >Now look bottom the page, and download one after one
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Intel DG31PR Motherboard
Is there any audio drive for DG31PR +windows server 2003 os
Use the site below to download the driver of your intel motherboard.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
Dec 02, 2009 | Intel DG31PR Motherboard
I have intel DG31 MOTHERBOARD BUT CANNOT INSTALL WINDOWS 2003 SERVER (ALL EDITIONS). THE MOTHERBOARD ONLY SUPPORTS WIN XP AND WIN VISTA
i have one solution to installed 2003 server in dg 31 pr
please open bios and hdd setting there are two option nativeor lagecy
you select legecy and then you r able to installed
viks.sheth@gmail.com
Mar 25, 2009 | Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Good luck ameyaniks!
If I missed something, just let me know.
Mike
Sep 11, 2008 | Intel DG31PR Motherboard
Intel DG31PR not supporting 2 dimm each of 1gb
Memory for Intel motherboards require the memory to be compatible with, Serial Presence Detect (SPD). Its suggested when upgrading memory for Intel boards or increasing memory to do you're search for the total memory you wish & include the Intel mother board model. Example: http://www.google.com/search?hl=en&q=Memory+for+Intel+DG31PR&btnG=Google+Search
This first link shows what brands works with the DG31PR MB.
Intel Tested Memory for DG31PR MB link:
http://www.intel.com/support/motherboards/desktop/dg31pr/sb/cs-027918.htm
You're Intel board is well within the Intel warranty. If you find this information not helpful please call Intel tech support. It is possible you're board needs higher attention. Please check & install the latest bios. Intel's link for bios, manual & drivers link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
If you are not using WinXP click this link & pick you're current operating system.
Mike
Aug 08, 2008 | Intel DG31PR Motherboard
Cannot install vista - BSOD
the processor is core 2 quad 2.4 ghz, and as far as i know it does support 64 bt os. also bios is updated to latest from intel site using flash drive. but there were no mentions in the bios about using 32 or 64 bit os
Jul 20, 2008 | Intel DG31PR Motherboard
Bios not acpi compatible
Hi zedy, you're bios is not compatible with ACPI. Toy understand this better read the Microsoft web site link posted below.
http://support.microsoft.com/kb/314088
You can try to fix this by upgrading you're bios software. Click on the link for bios upgrades for you're board Gigabyte GA-6VX.
http://www.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=1523
Good Luck!
Still have questions? Just ask.
If the solution provides great advice on how to solve the problem marked in blue FixYa.
Mike
May 21, 2008 | Intel Motherboard
Intel DG31PR Motherboard Logo
228 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
