Question about E-Machines Computers & Internet
I need to remove the cd drive from my emachines t5224.
    Scholar:
  • 51 Answers
Are you trying to remove the entire drive? or just a CD from inside the drive?
most CD drives have a pin-sized hole just below the drive tray (where you insert the CD) which will cause the drive to eject the tray as long as it is powered.
removing the drive itsself is not overly difficult either.
--Simply power off your machine, unplug it from the wall and wait a few minutes for any residual capacitance to bleed off (general safety precaution).
--Then open the outer case (normally held on by thumb screws or hex screws, you may need a screwdriver to do this)
--once the case is open/off, locate the CD drive inside the machine. simply unplug any cables AT THE DRIVE (do not unplug any cables at the main board unless you really know what you're doing or have to because often there are multiple things plugged in there and you could cause a more serious problem by doing so.)
--after everything is unplugged from the drive, locate the mounting screws and remove them (sometimes they are clips, other times screws or hex bolts). this will allow you to remove the drive itsself from the case.
--once the drive is out, put the case back on the machine and plug everything back in and you'll be good to go minus one CD drive.
hope this solution helps you, and please do not forget to rate me.
Posted on Jul 09, 2008
Help with emachine T5224
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Jan 14, 2013 | eMachines Computers & Internet
I have an emcahine T5224 it was given to me ive tried fixing it and determined its not the HDD because it loads the OS on my other computer and works just fine but for some reason it stops and says there...
You stated that it loads that OS on the other computer. Is this by taking out the hard drive and putting into another PC? If it is, then I would have thought there is h/w issue elsewhere in your PC...
Usually if you have a message saying that it could not load windows properly, it is an OS issue which I would recommend you fix by using your emachines recovery disks.
Hope that helps
Nov 11, 2010 | eMachines T5224 PC Desktop
I need the wiring diagram for emachine t5224 desktop pc
Do a Google search for " emachine t5224 manual", and get one. The manual should contain the wiring diagram showing how all components and cables are connected to the motherboard.
Oct 27, 2010 | Computers & Internet
I turn it on and the fan begins to spin up, blue power light comes on and then after about 30 seconds it shuts down
hi, probabily the procesor fan does not works , other options is your opering sistem is bad, format and reinstall windows , other option is your hard drive is bad , try with another hard drive
Aug 12, 2010 | eMachines T5224 PC Desktop
Disc tray will not open e-machine T5224
This is not uncommon with older CD/DVD drives.
There should be a very small hole on the front of the drive that can be used to manually eject the disk.
Straighten out a paper clip and insert it in the hole. It may take a little fiddling but you should be able to get your disk out.
Unfortunately, this indicates that you drive is failing so you should replace it soon.
I hope this helps.
Feb 21, 2010 | E-Machines emachines (emachinees) CD-ROM...
, I think I figured out the problem I posted earlier, I think the root of my problem is that I have been using a ubcd4win cd I created with a dell windows xp install disk and trying to use it to restore an...
You can download an OEM version from bittorrent sites, and as long as you have the genuine certificate of authentication label on the pc case you can install and activate it legally. Just make sure you get the correct version to match the label, e.g Home or Professional.
Oct 10, 2009 | eMachines T5224 PC Desktop
My norton scanner says my pc is infected with 4 trojan virus. how can i remove these virus now?
you have to have an antiviral program I would suggest CA as it is very efficient and not dear to buy.
Sep 26, 2009 | eMachines T5224 PC Desktop
How do i install a new graphics card in an emachine t5224?
If you're replacing the graphics card then it should go into the same slot as the one you are replacing. To do this, turn off the machine, remove the old card (if it's an AGP card they'll be a card lock on the inside end of the card where it plugs into slot). Remove the card lock, and then remove the card. Reinstall your new card. Keep in mind that your new card must be the same type as the old one AGP or PCI. The slots for these are different and you could damage the card and the slot.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Md52xcdr
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Sep 09, 2008 | Mad Dog Multimedia (md-52xcdr) CD-RW...
Emachine T5224
Repeteadly Press F1 during boot. Then at the menu press F8 to go to advanced options. Then select System Recovery, and you can get into the recovery manager to restore the original factory system.
Jul 07, 2008 | E-Machines T2742 PC Desktop
Computers & Internet Logo
62 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
