Question about Gear Head Wireless Bluetooth V 2.0 Desktop Set KBL8000WRBT
The PIN for my Wireless Gear 4PR907 is not 0000, 1234, 8888. Any suggestions as to what to do next. I just purchased this blue tooth new at K-mart but the user's manual is missing. There was some tape at the side of the package; I didn't think too much of it initially but now, I am thinking it was a return. Can you help? How would I reset the PIN?
Ear loop broken-purchased loops and they snap and break
nujanitoral.jpgDon't spend lots of money buying blue tooth headsets Go to your local Walmart and purchase the Emerson Blue Tooth headset it comes with 2 ear loops that are made of a flexible plastic and 6 inner ear buds for a very snugged fit. The ear loops will also fit your LG blue tooth headset. You can also purchase the headset by following this link http://www.walmart.com/ip/Wireless-Gear-Bluetooth-2.0-Headset/15852098
Jun 11, 2011 | LG Cell Phones
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
How do i make my backbeat 903 discoverable
Most manufactures of blue tooth devices use the power button to turn the discovery mode on,by holding the power button down for 6 to 10 seconds when turning on your blue tooth device a solid light should come on,that means your blue tooth is in discovery mode,then what ever device you are connecting it to has to have the blue tooth power turned on,then there should be a add new or search for devices,after thatyou will need a pin pairing code,Most manufactures use a factory 4 digit pin pairing code they are as follow,0000.1234,1111 or 9999 i hope this helps
Feb 22, 2011 | Plantronics Backbeat 903 Bluetooth...
I has sony ericsson blue tooth, my phone is nokia E72 how to connect?
By sony ericsson blue tooth i think you mentioned the headset. If you got the manuals for that headset, just check for the default pin code for the headset. But if not try these pin codes such as 1111 or 0000 or 1234 etc.
To Connect:
1. goto connectivity in ur mobile nokia e72. you will find it as a seperate icon in your menu, or you can get it from setting/connectivity.
2.in that switch blue tooth on.
3. now go to the next tab, and select options. from that select new paired device.
4. Now it will find the blue tooth headset. If it didnt detect, make sure your bluetooth headset is switched on.
5. then select that headset fro the search result and then it will ask for confirmation with the pic code.
type the pin code you hv gt from the manual or try these(1111 or 0000 or 1234 etc.). then it will accept. If its accepted, the bluetooth headset will start working!
Thanks, ask me if u gt any doubts.
Oct 06, 2010 | Cell Phones
Windows vista which USB cable do I need to use a
As far as I am aware the mouse you are talking about is NOT blue-tooth but a regular wireless mouse.
It came with a small wireless dongle that plugs into ANY regular usb port and does not need a cable.
Blue tooth does not usually use cables either as it is a wireless format but different to regular wireless
If your mouse is blue-tooth then you should ensure that your laptop or pc also has blue-tooth.
Should it not have blue-tooth then to use the mouse you would need to purchase a usb blue-tooth adapter. this is not a cable but is classified as a "dongle" you that's true !
This dongle plugs into any regular blue-tooth port on occasion windows will detect and install the required files but some blue-tooth dongles will come with a cd that you need to install.
If this information was useful please click
Aug 16, 2009 | Trust (14694) Keypad, Mouse
Need to know how to pair a wireless gear hands-free speaker phone/ model 4PR922 with mobile phone {don't have a manual}
press and hold the third button with the phone picture on it continuously until the light displays red/blue alternate blinking light (not just blue flashing, if you see blue flashing and no red, you didn't hold it long enough). Once that is going then turn on your phone's blue tooth setting to be 'on'. At that time the phone should see the bluetooth and try to pair. It will ask you for a pin (your phone will) the pin is 0000. Hope this works for you, prob depends on which model you have, I have wireless gear bluetooth, with 3 buttons across it, and the base of the unit is black.
Jun 18, 2009 | Cell Phones
Blue tooth will not pair with my new phone. keeps asking for a pin. i dont recall setting one up and dont have the manual anymore to remember the basic one it came with.
blue tooth will not pair with my new blackberry 8320. keeps asking for a pin. i dont recall setting one up and dont have the manual anymore to remember the basic one it came with.
Mar 21, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Gear Head Wireless Bluetooth V 2.0 Desktop Set KBL8000WRBT Logo
397 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
