Question about GE Spacemaker WSLP1100D Top Load Washer
Ge Washer GSLP1100D0WW keep getting a dr code near the end of the cycle it stops at 28 mins and then when i hit start it counts at 30 gets down to 28 again and does the same dr code again
Your problem lies in the PCB assembly, or pump motor, most likely the PCB assembly.
1. open lid
2. remove control panel screw covers & screws
3.lift control panel
4. remove screws connecting PCB assembly to control panel
5. Remove PCB from control panel by pushing PCB from right to left.
6. Disconnect wire harness connectors from PCB.
Hope this helps!
Posted on Jan 21, 2011
My maytag washer when i start it it fills then the cycle starts the timer will count down til it get to 13 min then jumps down to 3 min then shuts off it skips the wash cycle and the rinse cycle befor
sounds like you have a problem with the main control board. you can order a new one from appliancerepair.com and if it turns out not to be the problem they allow you to return it for a full refund. great company!
May 26, 2014 | LG Washing Machines
GE WBVH6240 front load washer runs on 38 min. of the speed wash cycle then stops and door unlocks at 18 min. Tried to restart via the drain and rinse cycle at 18 min., the water pump comes on but no spin...
Hello, Welcome to FixYa.
The first thing I'd suggest is removing the filter in the pump you spoke of and insuring the pump is clear...there may be alot of water though so hopefully you're close to a drain or have some buckets/towels handy.
If that fails to resolve the problem it could be a plugged or faulty pressure switch. Have you run a system diagnostic yet ?
Here's how and the subsequent code meanings...in the event you don't know...
Let me know if any of this helps or perhaps you cannot read it, It is all included in the service manual I can send via email if you could use it.
Good luck.
Regards,
Macmarkus :)
May 06, 2011 | GE WBVH6240F Front Load Washer
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Washer starts then stops and displays f28
hello southerndav4,
Welcome,
you said, you when the unit is started in any cycle it will lock the door and then run water in for a couple of seconds. It then stops the water and unlocks and immediately locks again. There is no further action except the timer counting down until f-28 code. There is no tub rotation and the ccu was replaced.
I see you did a couple of tests and replaced the CCU!!
You did do what I would have suggested.
You may need to use hands on service this time!
rather than swapping out expensive parts blindly!
Let me know...
Huum
Please remember to leave a rating
This is the condition fo the F28 error code
SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
This is what you need to check and or repair
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
Check connections of the CCU board within the housing.
Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Sep 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-11
FIRST COMMENT
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes / Procedure
5. Verify CCU operation by running a Diagnostic test or any cycle.
Replace failed component.
Jun 15, 2008 | KitchenAid KHWS01PMT Front Load Washer
"Dr" error code
Your pump is either bound up with something in the chamber, or there is something in your discharge hose blocking the water from escaping.
Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Check if there is anything in the chamber that is binding the impeller. If not, remove the metal back and check that all three of the hose connections to your pump are open and have no debris/ change, etc. If there is nothing binding your pump in any of those locations, your pump motor may be failing. I would suggest calling someone out to assist you.
May 05, 2008 | GE Spacemaker WSLP1100D Top Load Washer
GE Spacemaker WSLP1100D Top Load Washer Logo
513 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
