Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
A friend went to clean my machine and took the tray out the grinding unit? with the 2 red push buttons on either side became stuck then dropped and is now stuck so I can't get it out and the tray won't go in either. AHHHHHHHHHHHHHHHHHH
    Problem Solver:
  • 5 Answers
Unsure but if you try and get it in a little do you mean the whole thing drppped down or just the very bottom. usually you have to turn the machine of by the machine, not power point first, then it puts the dispenser type thing in location so it can be removed. if you have some how dislodged the tube from the bottom as you didnt turn it of right, up to you but it can be forced back in place just hope you dont damage it trying, i had same issue, and managed to get it back in, then power up machine then turned it of with the machine power button, then turned of power removed and cleaned it. It was hard to get the tube thing back to right place and it was near at breaking point. But all went ok in the end. hope this helps, if you turned of right it should just come out soon as you push in red clips and easily goes back in
Posted on Jan 08, 2011
I have the Vienna Superautomatica. It turns on, the green "on" light ilights the red light blinks on and off. The grind button has no effect. Nothing is clogging the grinder - sometimes there...
Hi
Blinki9ng red light usually something is not in place. The water tank empty. grinder empty or cloged, the brew unit not seated, dredge drawer not in place, or the usual cluprit is the drip tray. There can be something behind the drip tray that is keeping it from seating ( it has to lock into the 2 holes in the bottom of the base) Try to push the drip tray in and down and see if it will work.
May 16, 2011 | Saeco Vienna SuperAutomatica Coffee...
I was cleaning the grinder and brew cup. When i went to put the brew cup back in place i accidently pushed the PUSH button. Now i cant get it back in the machine. The gears to the brew cup seam to be off...
Hi
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must insert the drip tray and dredge drawer, close the door and turn on the machine without having the brew group in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray, and test.
Apr 05, 2011 | Saeco Incanto Classic Espresso Machine
How do you open the machine to clean out the grinds
There is a small rectangular button on the left side of the front cover. Gently push it in and the cover swings open. Now gently pull the drain tray straight out. The grounds will be in the square plastic receptacle at back of the tray.
Feb 18, 2011 | Solis Palazzo Espresso Machine
Hi i took out the brew group to clean and it wont go back in
Hi
You may have released the hold mechanism and it needs to go back. Follow these directions.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Feb 08, 2011 | Saeco Vienna Espresso Machine
The press nob when you open it will not press down it jamed and it will not come out it stuck
Hi
Directions for removing a stuck brew unit. Vienna.
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.bansheracer_0.jpg
Jan 17, 2011 | Saeco Vienna SuperAutomatica Coffee...
Brew unit is stuck
Open the door. Remove the dredge drawer, drip tray. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
Jan 02, 2011 | Gaggia Titanium Espresso Machine
Saeco Incanto Deluxe brewunit jammed
Mar 04, 2010 | Saeco INCANTO DELUXE Espresso Machine
My machine grinds coffee without stopping for what seems a long time, then the bean light comes on and it will not make a cup of coffee. I took out the brew unit and cleaned it, now the brew unit light...
Hi
You have a couple things wrong now.
First you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder (towards the rear of the machine). Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever on the right side below the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
The second thing brew unit missing.
Open the door. Push hard on the upper left side of the brew unit. When you hear a click, close the door and the light should be out.
Nov 16, 2009 | Saeco Magic De Luxe Espresso Machine
Ground coffee Saeco Royal
Hi
thedalys. you probably have a bad micro switch on your doser. and that just needs to be replaced. If the grinder does not sense that the doser box is full it will keep grinding until it times out.
Guest. Try pulling the dosage lever back one click from the full and push your grind lever to the largest # and see if that helps. Sounds like you grinds are too fine and its clogging the the grind box. If the dosage level is too full it will cycle and dump the brew unit or break the brew drive gears, then you will hear a clicking noise when it trys to make a coffee.
Dec 12, 2008 | Saeco Royal Digital Plus Coffee...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
326 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
