Outdoor heatpump unit,twx736a100a2, coils freeze over solid,replaced outdoor thermastat, checked freon and replaced a relay switch at a cost of $500/for 2 service call-outs.It worked fine whole month of a very cold dec.We had 2 days of 50' weather and now its back down in low 30's and coil froze solid again! should i call another tech.?whats next? reversing valve? control board?,thanks..going broke in ohio
  • 2,133 Answers
Coils freezing due to dust blocked coils and or air filter or short of gas. Service your unit completely.Please do not change any spare/s without knowing exact problem. Please follow the steps given below.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks. To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Posted on Jan 04, 2011
I have a LG air conditioner which seems stuck on defrost. It works fine in cooling but when on heat the defrost light comes.
Possibly a stuck or closed defrost sensor. The sensor gets to freezing which closes the switch. So the unit goes into defrost cycle which switches the flow of the freon on a Heatpump. The hot gas thaws the coil and the sensor. Which opens the switch and switches it back. I'm giving this answer without knowing more about the unit. Defrost light comes on & it doesn't run at all? LG system is a split unit or window unit or what?
Feb 19, 2017 | LG Heating & Cooling
Heat pump is not kicking in no heat at 42 degree outdoor temp
check the wirings.the coils and also the heating element.also check the heating temprature.
also check the power outlet.
connect some where else.
and try to restart it again after five minites.after you unplug the device from the electric outlet.
Oct 10, 2008 | Amana PTH123B35AE Air Conditioner
How much R22 should my unit hold when fully charged
If it has enough freon to freeze up then its not that low. Normally a 4-5 ton cooling only (non heatpump) will hold 7-9 lbs r-22 or 9-11 r-410a. Freezing can be caused by dirty air entering side of the coil also. Or slow blower
Jul 08, 2015 | Heating & Cooling
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
Apr 19, 2017 | Heating & Cooling
I have a trane outoor heat pump,twx736a100a2,coil freezes over.I had service tech. come to repair it twice,replaced relay,outdoor thermastat,checked freon,$500!..It worked fine for entire cold month of...
THERE is not a whole lott left not quite sure what all you have had done by post but i will let you know that the unit will run on a timed period based on outdoor defrost control board and once that time elapses and unit is still runnning it will check the defrost thermostat on the coils if the coils are cold enough (ie: frosted) the thermostat will send a signal back to board to go into defrost. the reversing valve actually switches back over to a air conditioner while mean while your indoor supplemental heat comes on rather it be electric or gas if they have it wired right. so that being said you could have a bad defrost control board if they have already replaced the thermostat outside. also if unit is low on refrigerant will freeze up ...lastly i want to point out not sure what your location is but when it gets down to 30 degree temps the heatpump will frost up it shouldn't be a block of ice but will frost up and look like snow on in completely normal. i tell people here in texas with heat pumps anything below 35 to go ahead and run the emergency heat just so you have warmer air and a stable home temp... yes it does use more electricity initialy ,but if you can warm a house in 2 hours with e-heat and it takes the heat pump most of the day running what is really costing you more? hope this helps and good luck to you please vote
Jan 04, 2011 | Heating & Cooling
[frozen heat pump coil], freon checked,contactor replaced,outdoor defrost thermstat repaced..worked all of a very cold december,temp rose to 50 degrees for 2 days,7 once temp dropped again,coil froze up...
THE ONLY THING THAT CONTROLS THE DEFROST CYCLE is the defrost thermostat and the actually defrost control board. along with making sure there is enough freon in the system to switch the unit over and move the reversing valve when it is time... if they have changed the defrost thermostat and you are positive the freon level is good the it appears you may have a bad board on the unit.... be advised the unit should frost up in cold temps and is normally to have frost built up on it then will go into defrost mode. if the unit is freezing over then yes you have a issue.
good luck to you
Jan 03, 2011 | Heating & Cooling
THE OUTSIDE UNIT WILL SHUT OFF
some outdoor units have high and low pressure switches or sensors that will shut the unit off to prevent damage to your compressor, some high pressure switchs will cut off due to a dirty condenser coil check your coil it can be , cleaned with a water hose, make sure you disconnect power before servicing. if it is a low pressure switch your unit is low on freon
Sep 30, 2009 | Heating & Cooling
Air conditioner constantly running, not cooling house
Check and see if it is froze up. Check big line at outside unit for ice. check filter and replace as needed. Check outside fan to see if it is running. Wash out outside coil If fan and compressor are running and has hot small line at outside unit. If not froze up and coil is clean you will need to call in a pro. If compress over heated you may need to wait for it to restart if coil was dirty. Again make sure out door fan and or unit is running and clean.
Jun 29, 2009 | Goodman CKL49AR49 Air Conditioner
Does not heat - compressor switches on/off repeatedly
check outdoor fan if running. the outdoor coil will freeze up on heat cycle. or outdoor board if there is one is defective.it could be reversing valve as well
May 18, 2009 | Heating & Cooling
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
