PRINTER IS NOT WORKING,ITS SHOWING INITAILIZING ERROR.
  • 27 Answers
Hi Jeeti,
Please provide the OS and the Printer name
Gary
Posted on Jan 04, 2011
The printer does not accept print jobs and orange warning light is on along with green ready. Both lights sart blinking when a printing job is sent. The printer does not print. How can I fix the probl
Dear
I am not familiar with Ubuntu. So in case of windows SMART PANEL/EASY PRINTER MANAGER can be down loaded from samsung web this will show the errors that the machine has.
Try to print a self (demo page) pressing stop s/w a while. If it works check the life of toner cart.
Thanks.
Sep 19, 2014 | Samsung ML-2571N Laser Printer
CM2320 won't complete startup process and receive scanner error 5
The scanner has only 1 motor and when initializing moves the lamp to the end, where there is a photocell to detect home position. Possibly bad sensor or dirt on tracks which interferes with the movement. Clean the rails with alcohol may correct the problem.
Paul
Jan 04, 2014 | HP Laserjet CM2320nf All-In-One Color...
Wd30ezrx -cannot initailing anymore the disk
I haven't the slightest Idea what you're asking for (initailing??) I assume you mean the disk cannot initialize? or cannot load? or cannot boot to windows?
Oct 29, 2013 | Western Digital Caviar SE WD1600AAJS 160...
Prnter is not initailizing
printer driver cd install 1st
Jul 25, 2012 | HP LaserJet P2055d Printer
My printer canon 4412 not work the display showing on main switch e202-0002
hi my printer canon mf 4412 printer is not working it is showing error batten red light showing , display is not showing pls solve problem pls it is urgent
Apr 05, 2011 | Office Equipment & Supplies
The printer does not work. I have 2 errors that show up on the printer. they read: TFFS0 ERROR 01 TFFS1 ERROR 02 what do these errors mean? how can I get rid of them?
The printer does not work. I have 2 errors that show up on the printer. they read:TFFS0 ERROR 01TFFS1 ERROR 02what do these errors mean? how can I get rid of them?
May 17, 2010 | Xerox Phaser 6120N Printer
Desperados 2 Video Problem
Did some googling and found out that you might have too old graphics card. Also try updating your drivers.
Apr 25, 2010 | Atari Desperados 2: Cooper's Revenge for...
How do I turn on my RAM disk? (Dell 3100cn)
the print job may be too large for the available printer memory.
Your choices are one of the following:
Press to clear the message, cancel the current print job, and conduct the next print job, if any.
· Press Cancel to cancel the current print job.
· Press Menu to open the Stored Print and delete the current job.
To avoid this error in the future, do the following:
· Reduce the number of print pages such as splitting the print data.
· Increase free memory space by deleting unnecessary data in the RAM disk.
As for the RAM disk:
When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory.
Whenyou are ready to print the job, you must go to the printer and use theoperator panel menus to identify which job in the memory you want toprint. You can use this function to print a confidential job (SecurePrint), or verify one copy before printing additional copies (ProofPrint).
NOTE: The printer holds the job until you delete it byusing the operator panel or you turn off the printer. (This is the RAMdisk)
NOTE: Print and Hold functions require a minimum of 320 MBavailable printer memory. Also, you need to configure the RAM disksettings on either the OPERATOR PANEL OR THE PRINTER DRIVER.
NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs.
RAM disk is an option for that printer, but most users do not have thatoption, and if you accessed the menu for the 3100 on most of themachines in use you would receive that same error.
Although the printer itself shows " ready to print", this does not meanthat your computer is communicating with the printer. In Fact, thatmessage would show up even if you did not have it attached to anycomputer, as long as it was turned on and passed the self test.
More then likely the problem lies within the computer, NOT the printer.
To test the printers functionality, try printing a menu item, from the"reports" menu. Select either the printer settings, or the PCL Fontsreport. When selected, the printer should print which ever report youselected.
One thing you may want to check is to see if there are any print jobs "locked up " in the print spooler on your computer, and also make surethat the printer is not set to "work offline".
To do this, open the control panel, go to your "printers" folder, then double click on your printer.
This will open up the printer information for that printer. If there are any jobs in the print queue, they will show up here.
if there are any print jobs stacked up, usually it is the top job thathad a problem and is "stuck". This will prevent any job sent after thatto be held, pending release of that one.
single click the top job and either restart the job, or delete it.
Also, make sure that the printer is not set to work offline by clickingon "printer" from the menu and ensure that work offline is not checked.
Take this link and print it out. It will help you later when you get "other" error messages.
http://support.dell.com/support/edocs/sy...
Sep 18, 2009 | Dell Office Equipment & Supplies
No comms with my PC
Assuming this is a USB printer the first thing is to insure the USB port works that the printer is plugging into. Insure you have updated the USB drivers. Also you must install the printers driver FIRST as often it instructs the computer how to connect to the printer. Try both of these and let me know what happens.
Apr 10, 2009 | Lexmark Z1300 InkJet Photo Printer
Power led blinks - canon pixma pro9000
Your canon printer needs to be serviced. That error is treated with special lubricant applied to a cam assembly inside and above the sheet feed assembly.
Mar 22, 2009 | Canon Office Equipment & Supplies
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
