Question about Vtech SL80108 1.9 GHz 1-Line Cordless Expansion Handset
I have purchased a SL82318 Handset. I have a SL82318 system, with all three original handsets working perfectly. This fourth handset displays: "Connecting..." and nothing else. According to both the manual for this particular system, and the manual for a fourth accessory handset, the display should show "Not Registered" after a brief time (10 seconds or so). I have de-registered all hand sets and re-registered all hand sets. No help. I have removed both battery, wall, and phone power/connections for several hours. No help. It would appear the handset I purchased is already registered to another system and is searching for that system. The handset came with the battery disconnected but charged. I have attempted to reset the handset by removing the battery for several hours. No help. I have followed all manual recommendations. No help. AT&T Technical help is worth less than the manual, and so: No help. It would appear that I need to reset the hand set to some sort of zero state, that is, not registered to any base unit. How do I fix this problem?
  • Anonymous Jan 04, 2011
    This is NOT a Vtech model, but rather an AT
*331734#Menu Select on the handset should de-register that handset from the old base, then you can register it to the base as per the manual (put it in the base and hold down the handset locator button for 4 seconds)
Posted on Jun 13, 2012
  • 3 more comments
  • Bo Baker Feb 07, 2013
    After 3 frantic hours of trying to get the phone to work I ran accross your tip and "voile." Thanks
  • AJ Smith Aug 26, 2013
    2013-had the same problem and it worked *331734# then hit menu button and start the normal process (e.g., hold handset locator until red in light use comes on, etc). Thank you
  • robert garcia reyes
    robert garcia reyes Aug 04, 2014
    thanks a lot you save me a ride to att sales spot
  • david neylon
    david neylon Jul 27, 2017
    Amazing! This worked and solved an annoying problem. Thank you so much! New handsets are no longer available, and one would think the vendors for used ones would include this with the handsets thy sell.
  • Robin Klaas
    Robin Klaas Jan 20, 2018
    Thanks so much! Answer still works in 2018. This was for an AT&T SL80108. Thank you!!!!
    New Friend:
*331734# then hit menu button. Phone will beep then restart and display "not registered"
Posted on Jul 17, 2013
  • 3 Answers
SOURCE: Resetting the Handset
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
2. Select the DEREGISTER HS
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
Hope This Helps - It worked for me
Posted on Oct 02, 2008
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: how to deregister a handset without the base with which it orginally registered
I successfully reset uniden TCX800 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near LCD.
Posted on Feb 24, 2008
SOURCE: No Dial Tone 1 Handset
I think I have the same phone. You have to put the handset with no dialtone in the main charger for about 30 seconds to reset it to the base.
Posted on Dec 25, 2008
SOURCE: My vtech 5825 screen says NOT REGISTERED and does not work
Place the handset in the charger and press find handset for 4 seconds.This will register the handset. do the same for other handsets.
Posted on Sep 20, 2009
Hi, Bruce Kelly I have a Uniden DECT1480-3 That the screens on all hand set's say's SEARCHING. I can not get a dial tone so I am unable to make a call or recieve a call. Their is no dial tone and all of...
All of the handsets appear to have lost their
registration to the base and will need to
be first de-registered then re-registered.
It may be necessary to do this in three stages.
First be sure that all of the handset batteries
are fully charged.
Clear one of the handsets of its registration:
hold down both the [END] and [#] keys
at the same time until the display shows the
Since the handset is not recognized by its
base, select "Base Not Available".
Confirm the choice by selecting "Yes".
This handset will now display
"Handset Not Registered"
With "...Not Registered" displayed, place
the handset into the base unit cradle.
The handset should now dieplay
"Handset Registering"
After ~30 seconds the display should show
"Registration Complete" and will have a
handset unit number.
If the unit shows "Handset 1" (doubtful)
then just repeat steps 1 & 2 above for each
additional handset in turn. This can also be
the route if you do not care what the numbers
are and do not exceed the maximum count
for your system ( some are 4, 5, or even 12 ).
If the handset is a number other than 1 you
may want to clear the base & re-register
all of the handsets:
Using the now-registered and working handset
(number x), press both the [END] and [#] keys at the same time until the display shows the
This time, choose "Deregister HS" and the
System Reset Menu will prompt you to
select from the list of registered handsets
which one you want to deregister: choose
one that is NOT the one you have working.
Cycle around deleting them all until only the
one that is working is left: select that one and
the system will be ready to start re-registering
all handsets again from Handset #1.
Start at process (1) above, then (2).
Good Luck!!
Apr 07, 2017 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
Base el5200 will not reconize new hand set
To deregister the new handsets from their old bases and re-register
them to your base, try this for each new handset...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
I believe it is five handsets maximum for the EL52300.
If your system was fully populated ( ie, a handset is already # 5 )
you will have to clear all the handsets from the base and
re-register them in sequence ( it is the only way to 'rescue' the
places occupied by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button until the
"in use" light lights and then starts to blink ( ~ 10 seconds ),
release the button -- then press it again briefly while the "in use"
light is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset in turn: press
"Handset Locator" ~ 4sec ( in-use light on ), set handset into
the base cradle, etc.
The manual is available from:
but does not describe these procedures.
Good luck !
Mar 01, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
Load default Delta file message
Problem My handset displays either LOAD DELTA FILE or LOAD DEFAULT DELTA FILE. What should I do?
Solution(s) Tip 1 of 2
If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
Nov 16, 2009 | AT&T 650530003417 Cordless Phone
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
Handset problem
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
Nov 19, 2008 | NorStar M7208 Corded Phone
I can vouch for the second solution. It worked perfectly on my 2461 with two extensions. Even the vTech website was not able to provide a solution.
Dec 12, 2007 | Vtech VT 2461 Cordless Phone
Answering system
It first sounds as if the handset isn't charged properly. Check the battery status first. The manufacture advises to charge the system for approx. 7 hours before any use occurs. Second, make sure that the registration took, when programming the phone originally. I would de-register the handset by: 1 {MENU} i {0}{0}{2} 2 {3}{3}{5} i {OK} 3 Select the handset you want to cancel by pressing the desired handset number ({1} ? {4}). Then re-register by: 1 Handset: {MENU} i {0}{0}{1} 2 Base unit: KX-TG6021/KX-TG6022/ KX-TG6023 Press and hold {LOCATOR} until the IN USE indicator flashes. KX-TG6051/KX-TG6052/ KX-TG6053/KX-TG6054 Press and hold {LOCATOR/ INTERCOM} until the IN USE indicator flashes. LAfter the IN USE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 3 Handset: Press {OK}, then wait until a beep sounds. 4 {OFF} Third, make sure that the display on the handset does not show "SP-Phone" in the display, if it does press the phone icon button. Fourth, Do you currently have voicemail from your phone service provider? If so, the answering machine will not answer. Make sure that the answering machine portion is turned on. Do this by: Press {ANSWER ON} to turn on/off the answering system. When the answering system is turned on, the ANSWER ON indicator lights. When the answering system is turned off, the ANSWER ON indicator turns off. If there are any further questions or comments, please post here. Please rate this solution through fix-it. Thank you
Jun 22, 2007 | Panasonic KX-TG6021 Cordless Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Vtech SL80108 1.9 GHz 1-Line Cordless Expansion Handset Logo
857 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
