Question about Sony Cyber-shot DSC-W170 Digital Camera
I've got a Sony Cyber-shot DSC-W150 and I can't transfer photos to the computer. It says "The drive or network connection that the shortcut 'DCIM.Ink' refers to is unavailable". What will i do? I even tried using a card reader and it doesn't work!
larry james
  • 287 Answers
SOURCE: sony cyber-shot dsc-w150 display always reads "remaining shots 4"
In the menu you most likely have the size size at or near maximum. This uses up a lot of space on your card. Try reducing the size.
Posted on Jul 17, 2009
SOURCE: i am not able to view my files from my computer option
we can solve problem first connet the usb port to ur system & then choose menu from ur cam .in ur cam it shows memstick choose it show usb mass storage device clk it.go to mycomputer choose ur cam option & open it it will show DCIM File.from this we can copy ur photo........
Posted on Dec 29, 2008
welcomejee
  • 10594 Answers
SOURCE: User Manual for Sony DSC-W150 Super SteadyShot
Click Sony Support and download required manual of DSC-W150
Posted on Apr 13, 2009
  • 11967 Answers
SOURCE: Sony DSC-W150 has the infamous Turn the power off
Fixing a Lens Error on a Digital Camera This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 21, 2009
  • 411 Answers
SOURCE: Sony Cyber-shot DSC-W150. when powering on the
allienment with the mother board and also failure of the sensors of the lens unit,so contact sony service
Posted on Mar 02, 2010
How to transfer pics from sony cyber-shot dsc-w100 digital camera
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Mar 09, 2014 | Sony Cyber-shot DSC-W100 Digital Camera
How do you export images from the Sony Cyber-shot haRD DRIVE TO THE COMPUTER
Its quite easy just remove the Memory card from the Cyber shot
put it into the card reader and connect with your PC and simply copy and paste the images from card to PC.
You can also connect the Cyber shot directly to the PC using the USB data cable given with the Camera. When you do this a new drive will appear in My Computer now just copy the images from that new drive to anywhere in PC
Aug 28, 2012 | Sony Cyber-shot DSC-W170 Digital Camera
My Sony Cyber-Shot DSC-W150 no longer displays older photos on my camera. It now only displays ones taken since 1/1/2011. When I check on the computer they are all there. I would like to delete some older...
If the old photos are not displaying in the Camera, the most common reason will be the default folder structure might have changed.
I understand that you're able to view the old photos in the Camera by connecting it to the Computer.
In that case, you can delete the unwanted photos from the Camera after connecting the Camera to the Computer.
I hope it will resolve the issue. If you're still not getting enough space in the Memory on the Camera, you may transfer the new required images to a folder in the Computer and then format the Memory of the Camera.
Once you format the Camera, the memory on the Camera free up and you can copy the required new images back to the DCIM folder in the Camera.
Please let me know if you require any clarifications.
Jan 31, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
I can not copy my photos from sony dsc w150 camera to pc, i can view photo in camera only, please help me...
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jan 04, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
I wanna transfer pictures from a sony cyber-shot DSC-W300 to computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Oct 26, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
How to transfer pictures from sony cyber-shot DSC-T20 camera
Aug 07, 2010 | Sony Cyber-shot DSC-T20 Digital Camera
Mar 01, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber-shot dsc-w150 display always reads "remaining shots 4"
Jul 17, 2009 | Agfa Cyber-shot DSC-W150 Digital Camera
Transferring photo from computer to memory stick
Many cameras will not let you write to the card. Try using a card reader, which will make the memory card appear to the computer as a separate hard drive.
Nov 15, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
326 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
