Question about Fujitsu 36CS Air Conditioner
Good Afternoon to You, I am currently working on
Good Afternoon to You, I am currently working on a Fujstu Air Condioning unit model #ARXB36LATF and although there is sufficent power supply to the unit, the motor is still not working. I have checked the boards and all is well. Please advice on how I can attack this problem to get the motor running Thank you for your time and I wait your response Kind Regards, Nita Wekina
  • 2,133 Answers
This means error code of E-1 and E-2. Indoor room sensor defective. Replace it. And also rotate motor manually. If hard, replace fan motor bearings. Helpful?
Posted on Jan 04, 2011
I have a Rudd Achiever 10 . The unit was working yesterday morning, it stopped in the afternoon , and is still not working. The fan in the unit in the basement is working fine. Do you think it could just...
you will need to check you condenser unit(the outside unit) here is a website that may help,Tim:
http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-troubleshooting.html
May 30, 2011 | Ruud UBHC Air Conditioner
I have a 1998 Didge Caravan and for some reason the cooling fans will not shut off? Any ideas??
This is a general ideaof how it works. A temp sensor is attached on the engine. When the sensor determines that it needs cooling it send a turn on signal to the ECM or directly to a relay. The sensor using small amounts of current to turn on a larger amount of current to run the fan/fans. This is also shared by the air condioning system which turns on the fans to cool for A/C. Three possibilities: The temp sensor is stuck on/shorted or the rely is shorted or A/C switch is shorted. Most times the switch shorts to ground to activate the the fans. For example the engine temp turn on shorts to ground to cause the fans to come on. If the sensor is shorted all the time it is bad. You can trouble shoot with an OHM meter if your up to it or a good honest mechanic can easly find you problem. Good Luck
Nov 02, 2010 | 1998 Dodge Caravan
Good Afternoon! I've got an old sandwich top two-door with a broken hinge on the left door. The name-plate reads "Superior Products" but it obviously a Bev-Air manufactured unit. Currently, True is making...
Hello there:- on all the Hinges they 've a MFG name and a Number. if you can look at it on the back side of the broken hinge . Then you can get it from any refrigeration co. or any appliance co. too. try that . Hope this can help. God Bless.
Oct 08, 2010 | Beverage-Air Refrigerators
Our central air conditionerin our office stopped working this afternoon. We have replaced the fuse and batteries in the control unit ion the wall. is ther any other suggestions for troubleshooting the...
yes sir
please check the motor of the unit(the resistance of the windings should be equal) if no then send it for repair. and also check the belts for good condition if it is worn it wont work.chang it.
Sep 04, 2009 | Heating & Cooling
Tempstar Air Conditioner Not Working!
Remove the top of the unit and replace the fan.
Aug 22, 2009 | Heating & Cooling
Will not blow air of any kind...nothing
pls try to turn the fan with your hand if no noise( with power off) then change the capacitor
Apr 27, 2009 | Heating & Cooling
Installtion Manual
Do you have power cord installed on the unit? If so then you will have to have a receptical near the unit. You set the unit in a window following the instructions set forth in the manual, then you find a electrical receptical near the unit and plug it in. Follow the instructions in the manual for desired temps and fan speeds. There isn't any other necessary connections as the unit is one piece based on the model number the thread was posted under.
Mar 21, 2009 | LG LB1200ER Air Conditioner
Dometic air & analog thermostat control kit
Had one doing similar recently, and after a thunder & lightning storm. Nothing worked, but kept blowing 2 amp fuse in thermostat, when anything tried, heat or cool. Pulled plastic control box down from inside upper unit (AC) made sure breaker was off, took of plastic cover and smelled inside, and could smell burnt plastic smell. Replaced, control box, that got fan only working. Tried another thermostat , everything worked as it should. Turns out the lightning, or power surge, or whatever, shorted out the thermostat, and control box at same time.
Aug 03, 2008 | Dometic Rooftop RV Air Conditioner
Maytag AC afternoon out to lunch
Clean the condenser coil and change the filter.
May 09, 2008 | Maytag Chassis Built-In Air Conditioner...
Fujitsu 36CS Air Conditioner Logo
204 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
