Question about Apple iPod nano
Frozen 4G IPod
I was using itunes and i put eject ipod once the was eject my ipod screen froze i try putting it back on i tunes but it wouldn't go on my ipod wont move at all it is stuck on music i put in to itunes but it wouldn't connect
Try pressing and holding the center and menu buttons both at once until the apple logo shows up.. thats the normal troubleshooting routine.
Posted on Jul 10, 2008
16 gig ipod nano screen has frozen screen
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Jul 08, 2009 | Apple iPod nano MP3 Player
My Ipod is frozen
Press and hold the home button and the power button for 20 seconds.
Apr 23, 2017 | Apple iPod nano
Ipod nano 8GB 3rd generation FROZEN!
Try resetting the ipod while its connected to the computer by holding both the menu and center button at the same time for 6-10 seconds until you see an apple appear on the screen. You may need to repeat the reset. If this fails your looking at a hardware issue most likely. Good Luck.
Apr 19, 2009 | Apple iPod nano MP3 Player
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Mar 22, 2009 | Apple iPod nano
Frozen screen
First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
Jan 22, 2009 | Apple iPod nano
How do I Unlock Ipod screen if I forgot the 4 digit password?
There are basically three ways to unlock the Screen Lock on your iPod:
  1. The most obvious and will not work for most people (or else you wouldn’t be visiting this web site). Simply enter the 4 digit combination/pass code at Extras > Screen Lock.
  2. Connect your iPod to the first computer it was synced with or the computer set as the primary one in iTunes. Open the iTunes application, then disconnect your iPod from the computer, and it should no longer be locked.
  3. Use this final way only if the first two options do not work for you because it is a destructive process.
    Everything on your iPod will be erased.
    This should not be a problem if you have all of your songs, videos, and other media stored in iTunes and you can synchronize once again after getting the iPod unlocked. Besides, if you don’t unlock your iPod it’s useless right? Learn how to Restore your iPod using the instructions from Apple’s site.
If your iPod is simply frozen, follow my instructions for an iPod Lockup Reset.
I've tried the below method, and my music is still intact]
1. Plug in ipod.
2. Open “My Computer”
3. Look for the removable device (which is your ipod).
4. Open the folder, search for this hidden file : _locked.
rename or remove(delete) this file.
5. Eject your ipod.
Jun 03, 2008 | Apple iPod touch
hey billy, u have to download and install itunes to operate ur ipod on ur comp interface. only itunes recognizes ur ipod , and u can put songs or videos thro i tunes alone.. once connected to the comp the ipod ll say do not disconnect.. u hav to eject it in the i tunes,, der ll b an option for ejectin ur ipod on ur i tunes..
May 30, 2008 | Apple iPod MA446LL/A MP3 Player
My Ipod is frozen
OK what you need to do is reset it. To do this you will need to hold down the menu and select buttons simultaneously for approx 6 seconds until the apple logo appears on the screen. This should reset and un freeze your ipod.
Try this and let me know how you get on.
May 12, 2008 | Apple Mini IPod
Apple iPod nano Logo
75 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
