Question about Kitchen Ranges
We suspect out SF-8050 charger might have been misswired by someone. We need a wireing diagram.
  • 1 more comment
  • cjball Jan 04, 2011
    NO---this is a BATTERY CHARGER. A Schumacher model 8050. We need a wireing diagram besause someone might have misswired it and it is OVERCHARGING.
    I placed the question under "appliances" because that was the closest I could find to battery chargers. We STILL need a wireing diagram for a Schumacher 8050 battery charger.
  • cjball Jan 05, 2011
    This is a Schumaker Series SF model SF-8050 battery charger.
  • 1,998 Answers
0 results found for model # SF-8050
please provide the make and model number for the unit that you need a wiring diagram for Thanks again and Happy New Year Rick
Posted on Jan 05, 2011
  • Rick Ead
    Rick Ead Jan 05, 2011
    i suggest you folow this and call them directly beats paying the 20.00 manuals online wants for the manual which might not even have the wiring diagram in it
    F. Schumacher & Co.
    79 Madison Avenue, 15th Floor
    New York, NY 10016
    and there customer service department is
    F. Schumacher & Co.
    1325 Old Cooches Bridge Road
    Post Office Box 6002
    Newark, DE 19714
    Fax 800-862-3011
    800-523-1200
    info@fsco.com
    if you have any further questions of are unable to reach them please message me back and thanks again Rick
    F. Schumacher & Co.
    New York, NY 10016
    F. Schumacher & Co.
    Newark, DE 19714
    Fax 800-862-3011
    800-523-1200
    info@fsco.com
  • Rick Ead
    Rick Ead Jan 06, 2011
    hello ciball just checking in to see how you made out with the wiring diagram if they were able to provide it for you message me back with any further questions and when our chat has concluded please remember to rank how this opinion has helped in your appliance/charger repair Thanks again Rick
  • 441 Answers
The wiring diagram is inside the cooktop, it will be in a small envelope near the controls
Posted on Jan 04, 2011
  • 1 more comment
  • John Riley Jan 04, 2011
    Sorry, your issue was listed under cooktops.
    I am on it, I should have an answer in a few min
    I just talked with someone at shumaker, and he tells me a mini manual is inside the charger itself. If you can not find it or need more help try 800-621-5485.
Need a circuit diagram of a dewalt charger DE9108-xe 7.2V-18V one hour charger type 1:Q 96307-12/15 OUTPUT : 2.6A 7.2-18.0V 46.8VA
Can you (carefully!) measure the volts across them with a load (battery) and then the current through them by disconnecting one end, and if the charger is still working OK then they are V/I ohms, choose nearest value. 10k sounds very high, are you sure they aren't 1 ohm or less?
May 21, 2014 | Dewalt 7.2-18.0 Volt One Hour Charger
I am needing a wiring diagram o a 1972 dodge charger s/e, 400, someone has cut and taped off some of the wires, on the motor, so some of the wires under the dash gets hot, my brother said he could fix the...
Chilton manuals are the easiest way to go. They can be obtained through your local parts store (about $30 USD) and often at times come in handy for the typical DIYer.
Apr 28, 2011 | Dodge Charger Cars & Trucks
Do you know where i can find electronic diagram of hilti c7/36-acs
contact their tech support direct at 1-800-879-8000 for assistance
Nov 29, 2010 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
Hilti c7/36 I am looking for a electronic diagram
if the light on the charger are functioning ok. the problem is most probly the batterys. they dont last forever, replace the batteries and you should be ok.
Jul 20, 2010 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
Fischer and paykel scooter model sc231ala not charging
hi, if you got a meter , check the voltage o nthe charger socket , it should be about 24v,
that is the left and right pin, not the middle pin that is slighly lower,
if the voltages are going up and down goto the batteries first and chec k the connections on the terminal, tight ?, check them back the the charging socket, normally the charging socket is wires indirectly to the batteries.
Regards
GeWiz.
Jan 08, 2010 | Health & Beauty
Electric garage rolller door opens but will not shut.have checked limit switches,test ok,motor ok, checked wiring to circuit board,ok suspect one of two relays but not sure. would like to know if someone...
No diagram. Check your safety tx and rx units at the door bottom. If all is good, you may need to increase your down presure setting.
Big Daddy
Apr 18, 2009 | Electronics - Others
Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Mar 11, 2009 | Ryobi Multi-Volt Battery Charger
Broan Allure QS3
The Problem is the wiring. Take the 2 screws retaining the metal plaque off underneath the filters. You will see the wires leaving the motor going into a "molex" plastic connector which connects two another set of wires going to the control board. Check to see if the wiring colors match from side to side of plastic connector. Ive only seen it happen once but it was exactly that. I do service calls for broan & Nutone
Jean-Marc
Apr 29, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
