Printer access door open error message. nothing i've tried works
  • 113 Answers
SOURCE: Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Posted on Feb 28, 2009
manojro
  • 495 Answers
SOURCE: HP 6940 DOOR OPEN
Please restart your printer and then check if you get the same error.
Posted on Mar 23, 2009
komguy
  • 2306 Answers
SOURCE: my HP Officejet 7210 all in one is showing the
Carriage jam means the carriage, where you put the inks, can't move right to left properly. Sometimes ink on the clear strip behind it is the cause. You can carefully clean with damp Q-tip, and check also that the cleaning assembly on the right where the printhead parks, is not stuck.
Posted on Jul 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: Printer access door open
This is in the front. It is the door inside where you replace ink
Posted on Aug 17, 2009
  • 903 Answers
SOURCE: ricoh aficio sp 3200sf fuser door open error
There is a black sensor that detects when the fuser door is closed, and an actuator that the sensor either sees or doesn't see. If this sensor is dirty, it might not be seeing the actuator. It could also be broken or knocked out of place.
Locate the actuator on the side door (a small metal or plastic tab that sticks out from the door) and find the corresponding sensor. Make sure the sensor is in place and not broken or moved, and make sure it's connector is well-seated. If you have a can of compressed air, blow it into the sensor to clear away any dust or dirt.
Posted on Jun 19, 2010
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
I have an HP C6380 it comes up with the error message "Ink cartridge access door is open" It isn't but I can't override the message. Any help?
Please follow the next steps:
I also tried this:
1-power off unplug power cable wait for a minute
2- Press and hold both "#" and "6" keys Plug-in power chord
3- Be patient Wait for the screen to blank out.
4- Release #6 keys press power on button
Mar 19, 2013 | HP Photosmart C6380 All-In-One InkJet...
My canon copier D420 had a paper jam. can't get the copier to work now.
Try checking the paper path, there might be a broken or loose gear in there, a bent wire or stuck debris. If you done this and all seems ok but the error message keeps flashing, try to do a hard reset. That usually clears off error messages. If nothing happens, you might need to call a technician.
Feb 07, 2013 | Canon New Usa Imageclass D420 Laser...
Samsung CLX-3185
Hi
Have you checked the cartridges access door?
If so,try disconnecting the printer and leaving it for a long period [like 1hr] before connecting again.
Feb 28, 2012 | Samsung CLX3185 AllInOne Laser Printer
Code 3514 keeps coming one
Error: "Rear access door open" (3514)
How do I resolve the error message "Rear access door open" (error code 3514)
To clear the "Rear access door open" error message:
  1. Remove the rear access door from the printer.
  2. Reinstall the rear access door on the printer and verify that both latches are securely engaged.
  3. Unplug the AC adapter from the printer.
  4. Plug the AC adapter back into the printer.
  5. Wait for the printer to initialize.
  6. Verify that the error has cleared.
Mar 18, 2011 | Kodak Office Equipment & Supplies
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Feb 07, 2011 | Kodak ESP 5 Printer
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
Error # 3802
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  5. Close the printer access door.
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error continues, contact Kodak.
Nov 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer shows error code 3802 printer will not print
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a kodak 5500 aio printer. I replaced the
Try the following:
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
22 people viewed this question
k24674
